Turns out that my wiper motor & parts vanished, so, now I need a replacement, any help would be appreciated. 914-628-019-10-OEM is the part number for the motor, it the rest the same as a 4??
Either way, looks like I need a replacement
TIA
914Sixer
Apr 25 2015, 03:43 PM
Byron, The -6 wiper rack is completely different than the 914-4. Motor mounts 911 style, different angle than the 4.
stevegm
Apr 25 2015, 03:47 PM
QUOTE(914Sixer @ Apr 25 2015, 05:43 PM)
Even the wiper arms are different, IIRC.
racerbvd
Apr 25 2015, 07:26 PM
QUOTE(914Sixer @ Apr 25 2015, 02:43 PM)
That is what I was afraid of Will an early 911 one work, if I can't find the correct rack & motor?
914Sixer
Apr 25 2015, 10:12 PM
Yes, you can take a tubing cutter and shorten the 911 rack and install the -4 wiper arm assembly. Remove the strap and drill a hole for the post mount. You then have a -6 rack.
911 wiper motor will need a harness made up to plug into column harness.
sixnotfour
Apr 26 2015, 09:49 AM
QUOTE(914Sixer @ Apr 25 2015, 09:12 PM)
