Went to install a 36 tooth wheel for my megasquirt.
the mounting bracket supplied would work great with a stock set up, but I forgot to mention that I am running a full flow oil pump cover set up...everything is in the way
so I made a bracket and added spacers to relocate the sensor at about 90 degrees.Click to view attachment
checking the fit with the fan cover in place.
close fit sensor to wheel distance.
sneak peak at nickies hiding under the tin.
