Full Version: Please Delete
914World.com > The 914 Forums > Classified Forums > FS/WANTED: 914 Cars and Rollers
Mike1981
please delete
JRust
Looks pretty good to me at that price. Has some nice bits with it. Wouldn't consider it a daily driver with the current setup. A little more interior I'm sure it could be. Roll bar setup looks a little funny to me. Far from a n expert there though
Mike1981
Thanks
Added 2 pics of exterior
914forme
Need engine bay shot, under battery, for the price not bad, worse case is you get another chassis. But we have all seen a lot of 914 brought back to life on these forums.
BTW, I'd cut the cage out. The from drop should be perpendicular to the logs. Also needs some diagonal bracing. Also does not look like it ties in anywhere up top. Normally they tie in on seat belt bolts. And would not know unless it has an inspection hole, what the tube thickness is. Could be Exhaust tubing. One way to know, is hit it with the round end of a ball peened harmer. Proper spec DOM will not dent, with out serious force, exhaust turning will. Not good for negotiation.
Of course you could also take an Ice Pick to everything, and start reducing price by the amount of rust you find.
BTW, the monster decal adds 10Hp to the car
Mike1981
Added engine bay shots
Thanks for the responses
It is helping me warm up to this car
Mike1981
Yes
Planning to cut the cage out
Remove back wing
re-mount gauges from the roll-bar
Fix brakes-tires-caliper
Compound-Polish-wax
Change fluids
vacuum/scrub
fix little things
Not going to consider it a daily driver
just a sporty weekender
Still worried about fixing the tranny would you think $1000.00 for this
Thanks
Mike
JRust
QUOTE(Mike1981 @ Aug 30 2015, 07:58 AM) *
Fairly common issues there. Get DR Evil's CD & fix it yourself. Probably just needs dog teeth & Synchro's. May just be linkage bushings though. I'd start with all the linkage bushings. Then move onto the tranny. If it is the tranny. Pickup a used one & try it. Worst case at least you have more spare parts to rebuild one box. Tailshifters make great donor's for rebuilds smile.gif
matthepcat
Just convert it over to a Subaru trans and cable shifter.
914forme
Zip ties holding overflow bottle or Air purge bottle to engine lid torsion bars. headbang.gif
No shot of the Hell Hole, but then, if you are wanting a project, this one will be a project.
I second the Subaru Transmission, easy swap, cable shifter, makes it feel like a modren car. Need to fabricate trans mounts, and shifter assembly, but thats not a big deal or you can get a bud to help.
Mike1981
Thanks Everyone
I asked for shots of the hood, trunk as well as the longs and hell hole
I have had no response......
Maybe this will not happen?
Mike1981
Hello
Owner did get back to me
Has a soft clutch and 1st gear grinds
Also has problem with steering rack
I m loosing faith in this one
Any advice?
Mike
dflesburg
My advise, buy my GT you know its what you really want most.
Mike1981
QUOTE(dflesburg @ Sep 4 2015, 05:21 AM) *
If your talking this one
http://www.ebay.com/itm/Porsche-914-GT-wit...714485#viTabs_0
Yes that would keep me happy
Broke and Happy
Invision Power Board © 2001-2024 Invision Power Services, Inc.
