914Sixer
Aug 29 2015, 09:30 PM
I put the roll bar pieces on Monday using 3M 77 Multipurpose Glue. Car has been in garage the whole time. Peeling off as we speak. You can run you hand along the side and the material begins to bubble up Tried to show it in the pictures.
Now to start all over
Mueller
Aug 29 2015, 09:40 PM
The 90 stuff works better, but I've used the 77 on my speakers in my garage and they have held up fine....did you spray both sides and let get tacky before attaching?
euro911
Aug 29 2015, 09:47 PM
I haven't had good luck with '77' either. Glued the top parts of the door panels over the window lips and the targa top pad ... they held up for about a week
914Sixer
Aug 29 2015, 09:49 PM
Yes, I took the time to read the directions. Made sure it was tacky. I NOW remember Mark (914 Rubber) saying something about it was NOT an ideal glue for this application.
76-914
Aug 29 2015, 11:23 PM
Haven't used it in years. Find a auto upholstery supply and but whatever they sell.
bahnzai
Aug 30 2015, 04:36 AM
Wow, I wish I had know this earlier too. Spent the better part of a day doing that install. Guess we will see how that holds up now...doh!
Porschef
Aug 30 2015, 05:44 AM
Ouch, that's unfortunate. I ended up using 90 when I redid mine about a year and a half or so ago, and haven't had a problem. I had it on hand and would have used the 77, thinking it might be overkill.
In retrospect I should have peeled the old vinyl and painted the sail panels to match the car. I like the look better...
ConeDodger
Aug 30 2015, 06:52 AM
77 not made for getting hot. Sunlight will reactivate adhesive.
EdwardBlume
Aug 30 2015, 07:23 AM
QUOTE(ConeDodger @ Aug 30 2015, 05:52 AM)
77 not made for getting hot. Sunlight will deactivate adhesive.
Going on its loose too. I used the can as a roller and rolled the air out. You might get a few happy years out of the 77 if you stay on it as it dries...
puffinator
Aug 30 2015, 08:23 AM
I used 3M 80 and it worked out fine. I also tried 3M 74 and 77 and was not pleased with either.
Shadowfax
Aug 30 2015, 08:40 AM
I'm planning on using DAP Weldwood contact cement. Used it on a BMW E30 headliner a few years back and it worked better than the spray adhesives I tried initially.
stinkindiesel
Aug 30 2015, 09:38 AM
I had a similar experience with a VW Golf headliner and 3M 77. Lasted about 6 months before it started to come loose again. At the time I did it, 77 was what everybody else was using, but Texas summers tend to break down adhesives faster...
Gary
