stinkindiesel
Oct 6 2015, 02:59 PM
I understand the intake runner hoses that seal the intake runners to the distributor housing on a 1.7L are no longer available. That's PN 022 133 241 B. What are people doing as a replacement? Just find some heater or radiator hose that fits tight over the tubes?
Gary
walterolin
Oct 6 2015, 03:41 PM
Think the PN changed to 039133241. Google this number, several vendors including Pelican for 4.25 USD per.
Bob L.
Oct 6 2015, 03:44 PM
JawjaPorsche
Oct 6 2015, 04:20 PM
Some are using 2.0 hose (which are bigger) and using water hose clamps for a good seal.
Dave_Darling
Oct 6 2015, 04:21 PM
I believe those are the wrong diameter. The "039" part number makes me think that those are for the 2.0 motor, which uses larger-diameter intake runner pipes than the 1.7 does. (The 1.8 uses the same size as the 2.0 ones.)
You'll have to clamp those down quite a ways to make them fit, I believe.
See if you can find radiator hose of the correct diameter, that's probably a better option.
--DD
McMark
Oct 6 2015, 05:45 PM
Silicone hoses off eBay. I'll look for a link.
http://www.ebay.com/ulk/itm/251331765396
stinkindiesel
Oct 7 2015, 12:25 PM
Thanks, guys.
I actually have a set of the 1.8/2.0L hoses I ordered before I knew they weren't all the same. Guess I'll just take an intake runner down to the FLAPS and see if I can find something that fits.
Gary
