This is a group buy for front bucket LED boards. Please respond here if interested. I will PM you with payment details.
Available in two configurations:
1) US Version: 69 AMBER LEDs: $125/pair
2) Euro Version - w/Blanking: 21 WHITE LEDs in clear of lens; 48 AMBER LEDs: Price: $145/pair
Shipping:
CONUS: $10
Canada: $25
Outside CONUS: Determined at purchase.
CONUS payment examples:
US Version: $125 + $10 = $135
Euro Version - w/Blanking: $145 + $10 = $155
Each pair includes:
o 2 PCBs
o US Version: 69 AMBER LEDs.
o Euro Version: 21 WHITE LEDS (Running lights) and 48 AMBER LEDs (Turnsignal).
Euro Version with blanking will turn off WHITE LEDs when turnsignal is engaged.
Pigtail with 1157 base to plug directly into existing bulb socket.
4 clips for each pair to mount the boards to existing front bucket housing for plug-n-play installation.
4 screws for clips + 1 extra
1 piggyback spade connector if existing turnsignal flasher is replaced by EP36 LED flasher from your FLAPS.
1 year guarantee
Electrical Characteristics US version:
Turnsignal: 0.39A @ 14V (5 Watt) each PCB
Running light: 0.07A @ 14V (1 Watt) each PCB
Example front LED board shown with only tools needed: large Philips screwdriver for lens screws and smaller Philips screwdriver for PCB mounting screw.
Installation of the front turnsignal bucket LED boards.
There are 2 clips for each board. The small one goes in front the the long one on the rear.
Screw in the rear clip.
The small front clip mounts on the top of the board. These will be screwed in when I build the board. The bottom of the board will contact the bucket base to keep the board straight.
Here's the board ready for installation with the bulb base connected.
When installing the board, make sure the pigtail does not interfere with the rear clip.
Gently slide the board in. There are slots on either side of the board to clear the guides on the sides of the bucket.
Ready for the lens. The lens will hold the board in place. If you need to reposition the board, do not grab the LEDs as they will move. Use a paper clip or similar wire to pull the board out.
