Full Version: 74-1.8L
catsltd
My 1.8L motor needs some help.
I am at a loss as to where to start,but thinking the heads are as good as place as any.
So been reading everywhere and still have questions.
1, Can I pull the heads while motor in the car???,if I got to pull the motor Im screwed as a rebuild is not an option.
2.What do I do with the heads once I pull them???.Cant ship to USA as exchange rate is brutal.
So what can I do,local shop took me to the cleaners last year so feeling a bit lost as to options.
3.I cant find a thread on pulling heads,even in search,suggestions or link would sure help.
4.Car runs good new injectors Mallory dizzy,new plugs,etc but oil dripping and big puffs of blue between shifts is bumming me out.
5. Should I bother with a compression test with so many leaks.
Really love my new car,but totally overwhelmed right now.
Thanks for any help.
Grant.
ClayPerrine
QUOTE(catsltd @ Apr 2 2016, 08:56 AM) *
Grant.
Grant,
You can't pull the heads while the engine is in the car. But you shouldn't have to. The heads won't leak unless they are badly cracked, so I wouldn't worry about that.
Start with replacing the push rod tube seals, the oil cooler seals, and the oil pressure sender. All of these can be done with the engine in the car, and they are all well documented on this site. The bonus to the push rod tube seals is you get a valve adjustment and new valve cover gaskets during the fix.
You might also check to see who in your area has a 914 and would be willing to help. There are lots of guys on here that will come over and help wrench on your 914 for some hamburgers and a few beers.
catsltd
QUOTE(ClayPerrine @ Apr 2 2016, 10:02 AM) *
Grant.
Grant,
I got the valves adjusted last year at a shop,car didnt ,make it home before oil was drained and oil light came on,so thats why I am going to do as much work as I can myself.
Would be great to see some local 914 motors to look at,is there a place to look for local owners???.
Thanks.
ClayPerrine
QUOTE(catsltd @ Apr 2 2016, 09:27 AM) *
Grant.
Grant,
Thanks.
I couldn't tell you about any local owners in Calgary. But hopefully someone will chime in here.
Adjusting the valves won't fix the oil leaks. But you have to remove the rockers to replace the pushrod tube seals, so you get another valve adjustment anyway.
Take some pictures for us and we can try to help from here.
Valy
The big pufs of blue smoke usually means you need new rings.
zipedadoo
I would start with a compression check. See if the motor is worth putting any more money into it.
TheCabinetmaker
Oil leak started on the way home after a valve adjustment. If they used the old gasket it's guaranteed to leak. If this was an experienced air cooled shop? If not, they probably put the gasket on wrong.
catsltd
QUOTE(The Cabinetmaker @ Apr 2 2016, 11:55 AM) *
Ill start with oil cooler seals,and pushrod tube seals,since I am pretty sure I have the parts already.
I will do a compression test as well.
Ill post up what I find along with a few pictures as well.
I have the flu but will start on things tomorrow.
Thanks to everyone,I feel with the support here I should be able to get things figured out.
The car does blow out blue between shifts,but not always,so finding the oil leaks is proably my best place to start.
Both heat exchangers are dripping oil when I get back from a drive,so I for sure have oil coming from a lot of places.
Thanks.
TheCabinetmaker
Smoke when you shift (engine deceleration) is an indication of worn valve guides
jim_hoyland
QUOTE(The Cabinetmaker @ Apr 2 2016, 12:46 PM) *
Would worn valve guides make a ratta-tat like sound ?
bandjoey
valve adjustment not done right. pushrod tube seals old. wrong valve cover gaskets. also front right side, oil cooler gaskets. These are normal maintenance items that leak over time, and not hard to replace. search here and you'll find the exact way to do it all at home with no special tools. Oh, and depending on the motor, top of the heads inside the motor compartment there might be oil vent tubes poking up between the spark plugs. They should have a hose sending the oil vapors to a catch can or back into the intake system somewhere. I'm sure others will cover this in better detail. All done in a days work at home. It's a simple motor. Good luck and post pictures. It'll help us more in knowing how to help you. thisthreadisworthlesswithoutpics.gif
ClayPerrine
QUOTE(bandjoey @ Apr 2 2016, 06:59 PM) *
No head vents on a 74 1.8L
Invision Power Board © 2001-2024 Invision Power Services, Inc.
