QUOTE(Luke M @ Sep 30 2016, 01:00 PM)
Check the link... Keep in mind that the 930/911 turbo has a wider track.
74 to 89 911 front hubs are the better ones to use.
http://www.914world.com/bbs2/index.php?showtopic=286554Hi Luke,
Thanks for the link.
I am looking to go with 3in spacing struts, M calipers (or maybe Brembos), and 20mm Disks to keep the weight down. I was just curious if the 40mm or even 32mm hubs would be a better choice than the 47mm with regards to fender clearance or other issues. The 47mm hubs are easy to find so if they are ok to use I will just pick up a pair.
-Andrew
