Perry Kiehl Clone
Oct 27 2016, 02:11 PM
8 years ago I drove over to Kyser, WV to pick up this frame bench, it was about a 1500 mile 3 day banzai run. A little rough, but something to build on.
It had been sitting in another building of mine and we've done some cleaning and moving to make the space for it and the project on the rotisserie. This thing is big and h e a v y!
We've take the casters off the left side to clean them and glue the poly tires on the aluminum wheels.
Perry Kiehl Clone
Oct 27 2016, 02:20 PM
Click to view attachmentThe casters have ball bearings in the swivels, and roller bearing on the wheel shafts. They were totally gunked with dead grease. So we totally removed and disassembled the casters.
Click to view attachmentSorry for the blurry pic. The brake was rusted to the point of not working
Click to view attachmentThe poly tires were loose and wouldn't stay on the aluminum wheels
Perry Kiehl Clone
Oct 27 2016, 02:28 PM
There are two leveling adjusters that were a little stuck. We had to resort to the acetylene torch, the little propane torch wasn't enough
Click to view attachmentAnyone got a 2 3/16" wrench??
Click to view attachmentYou can see the witness marks left by my 2 3/16 socket. This one wasn't too far down the thread, so we could use the impact. The other adjuster was bottomed out, so it took a 18" adjustable wrench to loosen it; a 16" isn't big enough
whitetwinturbo
Oct 27 2016, 10:19 PM
serious bench
r_towle
Oct 27 2016, 10:53 PM
Cool, I am still in the lead. 8 years and you are just cleaning up the frame bench
I got plenty of time.
rick 918-S
Oct 28 2016, 05:28 AM
11tenths
Oct 28 2016, 09:34 AM
I've got those same jackstands under my project.
For three years.
- Harry
sixnotfour
Oct 28 2016, 12:56 PM
Perry , judging by your pallet shelves you must have a fork lift..
I was lucky to get a UNIC strong arm lift with my caroliner bench,,
and ya Ive had mine for a few years .. did a bunch of pulls on my six though.
Mueller
Oct 28 2016, 01:13 PM
Am I the only one that sees some humor in the fact that you have to restore and fix the bench before you can in order to restore and fix a car.
Can you get new rubber for the wheels? What kind of adhesive are you using?
rick 918-S
Oct 28 2016, 01:48 PM
QUOTE(sixnotfour @ Oct 28 2016, 01:56 PM)
I used to have a UNIC lift when I had my shop. I have this low buck version i built now.
IronHillRestorations
Oct 29 2016, 06:44 AM
I have a early 70's Hyster H25E which has been a little tank since we got it in 1989.
Mike, I did a cursory search and couldn't easily find tires for the casters so I got a flexible 1 part adhesive that's a lot like "Shoe Goo" It seems to have worked pretty good.
skier2.0
Nov 26 2016, 11:24 AM
Brings back memory's,I was a Blackhawk distributes in the NE in the 90's. The best way to repair a car on the bench (Blackhawk or Cellette) with fixtures. Do you have the cross beams? or the pulling arm?
Nov 26 2016, 06:00 PM
I have three cross beams, and 40' of 6" x 2" U channel to make more cross beams. I'm also building fixtures. I don't have a pulling arm. I don't intend to be using it for collision repair.
Feb 8 2017, 01:51 PM
Four frame stands are the starting point. I went back, forth, and all around on how to to this. I used 2 x 6 U channel, which isn't really flat on the top, but I was able to get the stands to level out. I didn't want to make it this wide, but this has worked out well.
Click to view attachmentAlthough rusty on the right long, and hell hole, as well as a tap in the door post, this 6 chassis is perfectly straight at all the measurements.
Feb 8 2017, 01:58 PM
More of the right side
Front pinch weld clamp
Click to view attachmentBoth sides
Feb 8 2017, 02:05 PM
Feb 8 2017, 02:10 PM
Feb 8 2017, 02:14 PM
Rear cross member bracket
Click to view attachmentClick to view attachment I made the cross bar removable for access
Feb 8 2017, 02:17 PM
76-914
Feb 8 2017, 02:20 PM
That's very nice. There were some hours invested, eh?
Feb 8 2017, 02:28 PM
Sorry about the low res cell phone camera. Yes, lots of time.
cary
Feb 8 2017, 08:26 PM
Well done ...................
Mueller
Feb 8 2017, 11:23 PM
Very committed, I like it!
914Sixer
Feb 9 2017, 06:25 AM
Looking good
jd74914
Feb 9 2017, 09:06 AM
Looks great!!
Jeff Hail
Feb 10 2017, 12:51 AM
Must be 9-10 years since I spoke with you Perry. I called for Porsche parts and get the needle point store. At the moment it seemed odd and a bit funny. Thanks for those pieces I needed.
When you go to replace those casters go here. (and you will).
http://www.castercity.com/pwic.htm#Table - Casters
Feb 10 2017, 06:55 AM
Thanks Jeff. :
Vysoc
Feb 10 2017, 07:18 AM
Great web-site for Caster's!!!
Thanks, Jeff
Vysoc
rick 918-S
Feb 10 2017, 12:09 PM
