QUOTE(MikeM @ Oct 30 2016, 07:34 AM)
Thanks for the link!!
Mike, if you do remove the VR from the relay board, do NOT relocate it to sheet metal in the car and screw it down. There's a reason that Porsche attached the metal case to the plastic side of the relay board, they didn't want you to ground the VR case. Flip it around like it was shown in the link.
From my posting in 2007:
"As I said earlier, it looks like I have an alternator ground strap fault. If you have a similar fault, and add a ground wire between the VR case and ground, then ALL OF THE CURRENT SUPPLIED BY THE ALTERNATOR WILL FLOW THROUGH THAT JUMPER WIRE. It could easily exceed 20A, and could start a fire.
Bosch and Porsche must have recognized this potential problem and decided to let D- on the VR case float. That way, if there ever was a ground fault, you wouldn't have an unsafe ground current path. I should have known that this wasn't a design flaw - it was actually a safety feature. Smart guys, those Bosch and Porsche dudes."
Like I suggested then, any time you suspect you have a charging system problem, check to see if you have a poor alternator ground. Many cars lack any kind of alternator ground strap, and the only ground path is through the corroded hinge.
