timofly
Dec 5 2016, 03:31 PM
My 2.0 with stock fuel injection has a consistent missing at idle and all engine speeds. At idle, disconnecting the wire to the #1 fuel injector makes no difference, but disconnecting any other injector wire makes problem much worse and eventually stalls the engine.
The voltage reading from the #1 injector input plug varies from .19 to .28 volts at idle. That doesn't seem like much, but what should it be? (I didn't test another cylinder because I ran out of time to fool with it today.)
Plugs are new and valves have been adjusted. Seems pretty clear that the problem is at #1 cylinder.
TheCabinetmaker
Dec 5 2016, 04:45 PM
Just check the voltage on the others and compare.
timothy_nd28
Dec 5 2016, 07:29 PM
You will need a oscilloscope if you want to measure voltage while the injector is firing.
If it was me, I would replace the injector connector. They sell them with 8-10" of wire.
reharvey
Dec 5 2016, 07:56 PM
The injectors operate at 3volts. Got that info from a Bosch D-jet manual. Ray
timofly
Dec 5 2016, 08:33 PM
QUOTE(reharvey @ Dec 5 2016, 08:56 PM)
OK thanks. I missed that.
walterolin
Dec 5 2016, 08:47 PM
The signal is a pulse, nd28 is likely correct - you will need an O-scope.
Swap the injectors, might be a stuck injector.
If that doesn't work, swap the 1 and 3 connectors and see if 1 fires. If it does, it's the signal on 1.
I suspect spark.
Spoke
Dec 5 2016, 09:01 PM
You can use a voltmeter if you integrate the pulse width over the period from one pulse to another. If you assume the pulse width is 1/10th of the period, then the average dc voltage measured would be 1/10th of the pulse voltage or .28x10=2.8v.
Best to check the other injector voltages. You could Swap injectors and see if the failure follows the injector or is the connector.
timofly
Dec 8 2016, 08:16 PM
QUOTE(Spoke @ Dec 5 2016, 10:01 PM)
The failure follows the injector. Looking for replacement but local guy says $310 for one. I have four old ones that have been in a bag since I hauled the car out of a junkyard in 2006. I've tried two so far, and it's definitely better but still not right.
Frankvw
Dec 9 2016, 02:54 AM
Hi Timofly, you guys have Mr.Injector (*) in USA, I read good stories about them, only 17,50 dollars per injector...I wish we had that service/price over here.... just drop all 4 there plus 2 from your spare ones to have good spares as well.
(*)Of course there are many similair services/companies, but I just picked one that I see sometimes mentioned on forums.
timofly
Dec 9 2016, 10:38 AM
QUOTE(Frankvw @ Dec 9 2016, 03:54 AM)
Frank, thanks. I have already sent them a note. Good tip though.
