thanks for the comment. I just received a euro order on a carbon fiber version... the guy read the installation instructions and couldn't believe the disclaimer at the end..... And he is in France!
PRODUCT DISCLAIMER: THE INSTALLATION OF THIS KIT OF PARTS IS INTENDED TO BE UNDERTAKEN WITH THE UTMOST OF PROFESSIONALISM AND CARE USING SAFETY GOGGLES, GLOVES, AND APPROPRIATE BODY COVER FOR WORKING IN THE RESTRICTED AREA IN THE ENGINE BAY AND PASSENGER CABIN OF THE VEHICLE IN WHICH IT IS INSTALLED.
NO LIABILITY OR FAULT IS IMPLIED OR ASSUMED BY THE MANUFACTURER OR SUPPLIER OF THIS PRODUCT AS THERE IS NO WAY TO ASSURE PROPER AND COMPETENT USE OF TOOLS AND APPLICATION OF INTELLIGENT MANPOWER DURING INSTALLATION OR USE THEREAFTER.
IT IS THE RESPONSIBILITY OF THE USER TO INSURE THE SAFE USE OF THIS PRODUCT.. DO NOT INSTALL OR REMOVE THIS PRODUCT WHILE THE ENGINE IS RUNNING OR TURNING OVER. DO NOT USE THIS PRODUCT WHILE DRESSED IN LOOSE CLOTHING, NECKTIE, PONYTAIL, OR OTHER DRAPERY OR DISROBED CLOTHING THAT COULD BECOME SUCKED INTO THE VORTEX OF THE 911 OR 914 FAN HOUSING THEREBY DRAWING FACE AND ARMS INTO THE SPINNING FAN BLADES RESULTING IN CATASTROPHIC ENGINE AND LIFE FAILURE.
USE OF THIS PRODUCT OR THE ACCESS TO THE ENGINE BAY IS THE SOLE RESPONSIBILITY OF THE USER. BEFORE, DURING, AND AFTER INSTALLATION, INSURE THAT ALL TOOLS, CLOTHING, AND BODY AREAS ARE CLEAR OF THE ACCESS PORT AND THAT ALL PARTS SUPPLIED IN THIS KIT ARE SECURED AND PROPERLY REINSTALLED. NEVER TEST DRIVE THE VEHICLE WITH THE HATCH REMOVED.
The good news is that most of that legal ease is common sense... maybe.
