long story short, the PO cannot wire cars so assume the worst
first is first, im assuming this blue wire is for the horn at the ignition
i also found this blue wire attached to the relay board under the kneeboard. guessing this goes to the ignition
it is attached to the relay board here, same spade connector as the only non corroded terminal
this disconnected wire goes to ground i assume?
and lastly, what is supposed to go to the pole #6 on this connector?
