Sigh - followup to my first post
I pulled all the plugs today to do a compression test. My first time to ever do a compression test, so hopefully it was done right. seemed OK at 100-110-110-105
However! When I pulled the plug on cylinder 4, it fell out of the socket, and underneath the tin. I can't even see it. I got a boroscope-type thingy from Harbor Freight - I found the plug, it is lodged in there pretty good. Is there a way to retrieve this? Anybody else do something like this?
I am planning on _eventually_ pulling the engine to clean and go through hoses and wiring, but do I need to get that plug out ASAP, or can it stay there for a bit?
* This is what always stops me from working on cars - bad luck. Of course, in other fields, I say "You make your own luck", so I don't really believe in luck, but man, do I have some bad luck with cars. Or just plain incompetence
Thanks
pf
