You have it oriented correctly there but I can't say off the top of my head that you have the curled edge positioning correctly to the outside, now that I think about it.
Kansas 914
Jun 21 2017, 08:06 AM
QUOTE(db9146 @ Jun 21 2017, 08:02 AM)
That is where I am - I can't remember either and the chrome seems to fit 'ok" either way.
Jun 21 2017, 08:17 AM
I don't know either but I hope 914rubber makes some new ones. Mine are all rusty.
PanelBilly
Jun 21 2017, 08:18 AM
I think it's 180' out. Tall side toward inside.
Kansas 914
Jun 21 2017, 08:22 AM
QUOTE(PanelBilly @ Jun 21 2017, 08:18 AM)
Thanks Billy - let me play with it that way - cheers!
Kansas 914
Jun 21 2017, 08:23 AM
I think I like it turned 180 - tall side to inside. The chrome piece seems to slide on and align better.
Kansas 914
Jun 21 2017, 09:16 AM
QUOTE(mepstein @ Jun 21 2017, 08:17 AM)
Thank you for the link. I'd still rather buy a couple sets from Mark and there's always a bunch of other stuff to add into the order.
Kansas 914
Jun 21 2017, 10:10 AM
QUOTE(mepstein @ Jun 21 2017, 10:01 AM)
I agree and have 6 items in my 914Rubber.com basket as we speak.
I'm not sure he would make these if someone else already has?
Jun 21 2017, 11:35 AM
QUOTE(Kansas 914 @ Jun 21 2017, 12:10 PM)
I think URO made them -
Kansas 914
Jun 21 2017, 01:43 PM
QUOTE(mepstein @ Jun 21 2017, 11:35 AM)
You are probably right!
Having just installed mine I would like to see slightly longer threads on the new improved model so it could be started with a 8mm socket without the nut falling into the socket to the point it doesn't grab. I did get them started with my fingers (skinny fingers).
Wyvern
Jun 26 2017, 12:04 PM
^^^ Just put an extra nut or 2 in the socket and it will space it up to catch threads .
mb911
Jun 26 2017, 02:24 PM
Maybe i should make them..
rgalla9146
Jun 26 2017, 05:32 PM
Remove the holder from the body and slide it into the sail trim.... as I recall that will be a big clue. And don't forget the black plastic spacer (its a countersunk cylindrical item) that goes between the sail trim and body at the top screw.
