QUOTE(Spoke @ Oct 10 2017, 02:16 PM)
There's not much to the turnsignal contacts. What resistance do you measure when moving the stalk to either turnsignal?
Clean the contact with very fine sandpaper, clean with contact cleaner. Make sure the contacts touch when engaged. You may need to gently bend the contacts to make better contact.
I wouldn't replace it without understanding what is not working and whether the contacts can be cleaned and adjusted.
got mine working fine doing the same things,stock is best with a tidy up ,replacements can be a mixed bag...from rubbish to average.
