Full Version: 1976 Porsche 914 / 914-6 Six Conversion 3.0L
914World.com > The 914 Forums > Classified Forums > FS/WANTED: 914 Cars and Rollers
patssle
March 2019 Update
Pulled engine for maintenance: replaced spark plugs, distributor cap and rotor, oil/filter change, valve adjustment, checked all head studs (with socket), dash/interior/seals/bumpers wiped down with 303 aerospace protectant, carburetors cleaned, breather lines replaced.
Daily driving to work this week!
Car:
This is a 1976 Porsche 914 that has a 1981 Porsche 3.0L SC engine. Almost all work done to the car has been done by myself (except wrap, bodywork, and specialty rebuilt parts). I have owned the car since 2009. In 2010 I purchased a project 911 to swap the engine to my 914. After preparing the engine and collecting parts the swap was done in the summer of 2014. I have driven this car every fall and spring when there is nice weather. Mileage of engine and car is unknown. Annual driven estimates are 2-4 thousand miles. Engine pulls hard (stock is 180hp...with my tweaks is probably ~200) and is a true blast to drive in this tiny car. Previous owners gutted the car for autocross - this is a lightweight 914 with no radio, no A/C, no heat, no electronics, and no comforts. Interior is bed liner - no carpet. I do one or two autocrosses a year. No accidents under my ownership and never needed a tow truck. I also own a 2000 Boxster S that I work on myself as well. Houston disclaimer: car/house/neighborhood has never flooded.
$18,000
Issues:
Slight rust issues were fixed by my quality bodywork guy before being wrapped (paint underneath is faded red). Previous rust issues were already fixed before my purchase (battery hellhole). Racing seats need to be recovered or replaced - I have passenger seat but it is not in car. The oil tank oil filter mount was not drilled center so I am using a remote oil mount. This allows for extra oil temp sensors that are featured in the center console and for the remote fan. Engine leaks like any classic Porsche engine as does the oil tank through a fitting or mount (plans are to re-seal next time I pull engine for maintenance). Speedometer is not accurate - bounces around under 30 mph despite new cable. Wipers move slow but good enough for Texas inspection.
Extras:
I have the engine lid (2 of them - planning for GT lid), front and rear valence (not on car), spare w/ good tire mounted, 2 extra wheels, bin full of random parts, and the full factory service binder.
I do not need to sell and very much enjoy this car - I even daily it to work as it's reliable. If you are a certain distance from Houston I'd even drive the car to you upon sale.
Drive by: https://www.youtube.com/watch?v=XIIH5ZSfbTE
Complete engine swap photo album: http://imgur.com/a/k0Wtl
Oil cooler install (brace against muffler bracket was relocated to chassis): http://imgur.com/a/6u4ew
Rust that was fixed: https://imgur.com/a/oBksl
Random included parts: https://imgur.com/a/1BkPsiy
Specs:
1976 914 with a 1981 3.0L SC engine
1966 Weber 40IDA3C Carburetors (36mm main venturis; F26 emulsion tubes; 150 mains; 55 idles and 180 air corrections with 3 degree squirter nozzles)
MSDS 1-5/8 headers
DANSK Muffler Sport Polished Stainless Steel (84 mm Dual Tail Pipes)
901 Side Shift Transmission (Rebuilt by Mike Callas / Rennsport Sealy)
Patrick Motor Sports Engine Mount
Vellios Oil Tank w/ Filler Neck and Dip Stick w/ Gatorade Catch Can
Kennedy Engineering Flywheel & Stage II Clutch w/ TOB
MSD 6AL Ignition
Distributor rebuilt and recurved by Barry Hershon (23 crank degrees)
Alternator rebuilt by Houston Alternator
911 Starter
Mocal 25 Row, 235 Matrix Oil Cooler w/ Remote Thermostat
Engine oil cooler modified by Richard Johnson
Valvoline VR1 Racing Oil 20w50
Aeroquip Stainless Steel Braided Hose -16 AN Tank to Engine, -12 AN Everywhere Else
Tangerine Racing Tunnel Fuel Line
Gates LP (Low Permeation) Carb Fuel Line 5/16"
CB Performance Fuel Pump
3M 1080 Scotchprint Gloss Hot Rod Red Wrap installed by Undergroundgrfx
Turbo Tie-Rods
Bilsteins P36-0112-H0 Inserts
Mahle 5.5x15 Wheels
BFG G-Force Sport Comp 2 Tires
Front Sway Bar Installed (Rear available)
Following pictures taken 10/25/17 at work - I do daily drive it occasionally: https://imgur.com/a/bvsZw
patssle
Added pictures and updated price.
98101
The photo in front of the mural is especially nice.
patssle
Still available!
patssle
Monthly bump!
patssle
Monthly bump!
patssle
Still available. Did an autocross last month for the first time in a couple years - car was great!
2mAn
Great little car. I know this would be gone if it were a 75 or older, but Im still considering it. Any idea where the oil leak is coming from? What else does the car need?
patssle
QUOTE(2mAn @ May 14 2018, 01:02 PM) *
It has drip spots in several areas but they aren't gushers as a week parked at work might see one or two drops. I'd have to get under it to look to be specific. Definitely around the oil pan/plug area. And the oil tank itself which can be a bit random and sometimes does nothing and other times leaves several drops in one day- either the return or feed line needs to be resealed.
Definitely needs new or recovered seats. Engine lid installed and front/rear valences if desired. Eventually the shaft bearings on the carbs should be replaced.
Oh and I just installed a new battery.
patssle
Monthly bump!
patssle
March 2019 Update
JOEPROPER
I can't believe this car is STILL available... seems to be a great deal for little investment.
ValcoOscar
QUOTE(JOEPROPER @ Mar 27 2019, 01:28 PM) *
FREE BUMP!!!
idea.gif idea.gif But I'd be homeless and divorced if I bought this one.
plus broke!!!
Good luck!
patssle
Engine Health Information:
As previously mentioned - I have no idea on the mileage of the engine. Despite the car driving great for 10 years with it being a /6 for 5 years - I've ran some engine tests. Even with 2 questionable cylinders this car pulls hard and runs great.
2 compression tests done warm at different times
Cylinder #1: 157, 155
Cylinder #2: 155, 140
Cylinder #3: 190, 188
Cylinder #4: 170, 160
Cylinder #5: 167, 158
Cylinder #6: 171. 165
Leak down test done cold @ 100 psi
Cylinders 4-6: Less than 10% leak down all 3
Cylinder 3: 3% leak down
Cylinder 2: 40% leak down
Cylinder 1: 30% leak down
However - the leak down test was done after the car sat in storage for 6 months and without driving it. I'm not sure to the accuracy of the numbers but am still sharing them. I cannot solidly say where the air was escaping but I believe it was through the rings. Head studs are snug.
Spark plugs with 150 miles of run time do show some fouling on those 2 cylinders.
patssle
If there are any mechanics that would be interested in seeing the extra parts that I can include - let me know and I can send a link to a video documenting most of it. There is a bin of 911 engine parts along with other stuff that might be worth something to the right person.
Beebo Kanelle
Where in Houston is this car?
Where can it be seen?
patssle
OIL TEST
I can't believe I forgot I ran an oil test on this car! Here are the results from Blackstone - did the test when I pulled the engine for maintenance.
Mileage was a very rough estimate given my speedo is not accurate. Could be off by a bit. They made a note that the silicone is high and the cause could be sealer - this is likely an accurate statement as I did use a fair amount of sealer on the bolts for the oil tank (they pass through to the inside) and the return line into the tank.
patssle
Bump...still available. Still driving to work too!
Beebo Kanelle
Guys! I looked at this car.
Its a screaming deal.
If I weren't restoring 3 cars already, I would have bought it on the spot.
And, I still may... if I get permission.
2mAn
I think its a wonderful deal also, but the leakdown scares me and being that I wouldnt see the car until after its paid for and delivered makes me nervous... that and the lack of garage space. That said, I probably think about this car almost daily. Cant make any car decisions until the current anchor project in the garage is up and running...
Im still watching this space
patssle
If there's anything you or anybody want to see let me know!
https://imgur.com/a/TL8aEvA
I really should do another leak down test. As I mentioned that one was done cold and after sitting all summer.
flat4guy
Any way to make this a 75? haha. Looks like a great deal, just that Calif does not like 76 and newer cars, ugh. GLWS
patssle
How much can I sell this car if it was a 75 or older? Maybe I should do another engine swap into an older car. biggrin.gif
mtndawg
I live in California and would not buy a ‘76 because the state requires smog. If you’re not getting interest from people in Ca, this may be the reason.
2mAn
QUOTE(patssle @ May 14 2019, 06:41 AM) *
I think updated leakdown and compression numbers will be a better use of your time than dealing with swapping all of this into another car.
patssle
Here's a comment from a local guy who rode in my car at an autocross a year or two ago. He's part of the autocross committee for Lone Star PCA and is one of the top drivers.
"It was a very well put together car. Feels the way a 914-6 should feel. All the sensation of a factory car with the drivability and benefit of some modern upgrades. I’ve driven a few and the ones like yours with a few minor tweaks drive great."
914_teener
QUOTE(mtndawg @ May 14 2019, 06:56 AM) *
If it were a 74 or 75 I.d buy it.
Somebody in the Lone Star state has a helluva deal.
Glws
Invision Power Board © 2001-2019 Invision Power Services, Inc.
