Full Version: Pliers and screw driver names
cal44
Can you'all give me a heads up on the name (manufacturer) on the pliers, 10/13 open end wrench and screw driver for the tool kit 1974.
Thank you
raynekat
Are you talking about 914-6 or 914-4?
There's a good website for 914-6....someone here will know it.
TheCabinetmaker
He said a 74, If I read it right.
cal44
Yep.......1974 four banger. I have reference material but the tool brands are not evident, hence my request.
Thanks
TJB/914
QUOTE(cal44 @ Nov 9 2017, 06:04 PM) *
Thanks
Here's one, they are getting hard to find & expensive.
Tom
bbrock
This should give you all the info you need about tool kits: http://www.p914.com/p914_tools.htm
raynekat
QUOTE(bbrock @ Nov 9 2017, 03:41 PM) *
That's the website I was thinking of.
Looks the screwdriver is non descript.
cal44
Fellers........thank you so much for the intel and that website.
Appears the screw driver is non descript (nameless).
bbrock
QUOTE(cal44 @ Nov 10 2017, 06:03 AM) *
So non descript that when I found one rattling around in the trunk of one of the cars I owned decades ago, I threw it away thinking it was just some cheap Wal-mart crap tool. headbang.gif
cary
Hazet
TJB/914
QUOTE(cary @ Nov 10 2017, 11:24 PM) *
Hazet
Cal44 & 914er's
I found some misc tool kit parts (screwdrivers-wrenches-spark plug tools) & will post sometime next week after I take photo's.
BTW: This stuff is getting expensive and rare to find. I know complete 914-6 tool kits are in the $2k+ to $3k+ area and complete 914-4's are in the $500++ area if you can find them. w00t.gif
It only gets more expensive over time for these factory tool kits that got thrown away by everyone. popcorn[1].gif
Tom
Larmo63
The VW sourced /4 "tool kit" is basic crap. The only part worth anything is the tow eye.
maf914
What is the function of the U-shaped bent wire tool with hooked ends located next to the tow-eye in the above photo? idea.gif
bdstone914
QUOTE(maf914 @ Nov 14 2017, 08:17 AM) *
Early hub cap puller. There are two holes in the edge of the hub cap to use with that tool. The puller look longer than most I have seen.
maf914
Thanks, bdstone.
bretth
My 75 didn't have any tools with it but my leftover tools from my 68 camper sure look a lot like the 914 tools. I have go dig them out.
Mike Fitton
These tools were also in the VW tool kits and there are plenty available check EBay and the Samba. If described as a Porsche tool $$$ as a VW tool each tool is under $20ea.
mbseto
That bar goes with the jack also, doesn't it? The jack and the bar is all I have of the kit...
Invision Power Board © 2001-2024 Invision Power Services, Inc.
