Mikey914
Nov 30 2017, 11:50 AM
As many of you may be aware there has been a "Cheap" option, that lets say brand "E" has done a video on notating that they are smaller than factory and change the pre-load on the arm.
Brand "U" lets call them has an install video saying that they have recreated the factory part with the same "type and amount of rubber being used"
Technically not true because as shown in the video by brand E the durometer is definitely not the same from the deflection noted.
With all the BS aside we have made a part like the factory bushing and a special tool to help install these. One of the problems with installation of this part is the end that brand E glosses over. When you get to the part where the tube holds that end from sliding down the shaft you have a "sharp edge" from the metal the rubber can catch on. If it catches you will scar the inside rubber. This will make a second attempt more difficult.
We have made the delrin "tools" to allow you to use a 1/2" stainless rod with some nuts and large washers to install. There is a taper to allow the rubber to clear the edge of the A arm without catching it.
I had Cary do up one for me and fully document this so that you will have some instruction as how to do this. We are currently compiling and putting this together now.
Mikey914
Nov 30 2017, 11:54 AM
To be clear the delrin parts are the only "tools" we are providing. We figured that most of you have an Ace Hardware or Home Depot nearby and can acquire these for less than we can ship them for.
BeatNavy
Nov 30 2017, 12:00 PM
Yup, I'll need one set of these with the tool.
It would have been two but I already bought a set of "brand E" about 8 weeks ago. From the looks of it, this is a great value, and I could have saved a decent chunk of money. Oh well.
Mikey914
Nov 30 2017, 12:04 PM
QUOTE(BeatNavy @ Nov 30 2017, 10:00 AM)
What is their return policy? I'd pay you postage
GregAmy
Nov 30 2017, 12:10 PM
Perfect timing. I'm in.
Also will go along with other winter projects, including the door/seal rebuilds kits (with all options), and how are you coming on the targa/top seals?
BeatNavy
Nov 30 2017, 12:12 PM
QUOTE(Mikey914 @ Nov 30 2017, 01:04 PM)
They probably wouldn't be thrilled that I've done a "partial install" (bushings are in the collars, but not on the arms). Otherwise I'd take you up on it
Mikey914
Nov 30 2017, 12:16 PM
QUOTE(GregAmy @ Nov 30 2017, 10:10 AM)
we are finishing up the tools on the lathe now. Will be able to start shipping in a few days (tools)
Also doing a set of GBs aimed at suspension so we will be able to combine to the extent possible. There is one more I need to list but need to run a few errands 1st.
MikeM
Fantastic price!!
Sadly, I also installed brand"E" last spring.
Nov 30 2017, 12:33 PM
I’ve been waiting on these. Thank you.
Nov 30 2017, 12:38 PM
QUOTE(Mikey914 @ Nov 30 2017, 12:54 PM)
I just recently bought some threaded rod, nuts and washers to install some motorcycle headset cups and it was less than $10.
mb911
Nov 30 2017, 01:16 PM
I am in but you knew that.
bbrock
Nov 30 2017, 01:19 PM
I've also been waiting, so I'm in.
Mikey914
Nov 30 2017, 02:28 PM
We've also marked our product so you will not get imposters
Chris914n6
Nov 30 2017, 03:06 PM
These also fit the 911 arms right?
Are rear trailing arm bushings in the works?
CMONNETT
Nov 30 2017, 03:51 PM
I'd be interested in one maybe two sets.
Thanks,
amfab
Nov 30 2017, 03:57 PM
K i'm in
rmdinmd
Nov 30 2017, 04:29 PM
in for a set. thx
JamesM
Nov 30 2017, 04:59 PM
Id love to see a video to see how much of a PITA this is, but im in, with tools. two of my cars are on 45 year old rubber and the 3rd is on $500 worth of RSR parts so this seems like its worth a shot.
dlee6204
Nov 30 2017, 06:34 PM
I'm in
bigkensteele
Nov 30 2017, 07:59 PM
An early set of the bushings somehow landed in my mailbox, and the quality is first-rate. Compared to the poly bushings I was about to use, they are a no-brainer.
I still need to get my A-arms powder coated, but as soon as that is done, these are going on!
IronHillRestorations
Nov 30 2017, 08:12 PM
Are these available now on the 914rubber site?
iankarr
Nov 30 2017, 09:33 PM
QUOTE(JamesM @ Nov 30 2017, 05:59 PM)
I'll be making a video of my install. Coming soon....
yellowporky
Nov 30 2017, 09:42 PM
i would like a set with the tool please.
And what about trailing arm bushings?????
pete000
Nov 30 2017, 10:29 PM
I am still masking payments on the brand E I installed last year!
djway
Nov 30 2017, 11:16 PM
All In
Mikey914
Dec 1 2017, 01:08 AM
QUOTE(Chris Scott @ Nov 30 2017, 07:42 PM)
Up in the other thread. Yes we can combine.
Blake is working on getting these listed up. Should be ready tomorrow.
mark
theer
Dec 1 2017, 01:45 PM
I need these and the strut-top pieces.
Shadowfax
Dec 1 2017, 02:04 PM
In for one set with tools. Thanks, Mark!
Mike D.
Dec 1 2017, 02:17 PM
I'm in for 2 sets and the tool!
(now get to work making the rears
Mikey914
Dec 1 2017, 05:58 PM
PMs sent to all
restore2seater
Dec 2 2017, 12:32 AM
I'm in for a set.
moorepower
Dec 3 2017, 06:37 PM
I will take a set with the tool.
ottox914
Dec 3 2017, 08:23 PM
In for a set plus tool.
Mikey914
Dec 4 2017, 04:23 AM
Codes sent to all so far
MasterCylinder
Dec 4 2017, 09:46 PM
I would like a set with the tool.
914Sixer
Dec 5 2017, 07:50 AM
Set with tools.
mgphoto
Dec 6 2017, 04:41 PM
I'm in for a set and the tool.
Thanks, Mike
Camaro Mike
Dec 6 2017, 08:36 PM
Mikey914
Dec 7 2017, 11:00 AM
PMs sent ot all
914Sixer
Dec 7 2017, 02:13 PM
Ordered bushings and strut bearings yesterday.
914four
Dec 9 2017, 09:30 AM
In for a set with the tools.
Kelvin
jesse7flying
Dec 9 2017, 11:14 AM
I'm in for a set with tools as well.
Jesse
Mikey914
Dec 15 2017, 02:13 PM
Sorry guys, I messed up. We only sent out 2 pcs (should have been 4) for the bushings. We are correcting that today,
I appreciate your patience, I didn't oversee this myself, or provide Scott with the full details.
You all should have the 2nd half in a few days as I just finished packing these up.
Sorry,
and thanks again,
Mark
Chris914n6
Dec 16 2017, 03:26 PM
Since most of us will be doing only 1 car, maybe the tools should be on a rental program?
Mikey914
Dec 16 2017, 05:58 PM
For what it costs to ship back and forth, and keep track, thought it best to get these out there. I'm sure they could easily be loaned back and forth.
It looks like we shipped out over 20 tools.
Also theres a little tool hoe in all of us.
Mark
JmuRiz
Dec 18 2017, 07:49 PM
QUOTE(Mikey914 @ Dec 15 2017, 12:13 PM)
Sorry,
and thanks again,
Mark
Good to know, I only got 2 bushings...so I'll be excited to see the other pair soon-ish.
Now if only my car was ready for me to install them
BTW the parts look great packaged up (front bushings and tools, rear tubes and bushings and strut tops)...got mb911's muffler today too....hopefully this time next year I'll have a running car with all these goodies attached.
rudedude
Dec 18 2017, 08:02 PM
I know i'm a tool hoe and at least i got a full set for one of the cars.
euro911
Dec 18 2017, 09:17 PM
I haven't seen the 911/912 question answered yet, Mr. Rubber Oh, I'm in, but there have been so many threads regarding this offering that my interest in obtaining said product(s) may have been overlooked, so, in essence, I didn't receive a message with the 'secret code' (yet)
Mikey914
Dec 19 2017, 12:22 PM
QUOTE(Chris914n6 @ Nov 30 2017, 02:06 PM)
These do fit the 911 arms that the 914 part cross references. I believe 69-89.
The trailing arm bushings are also done and in another thread. We will be wrapping these all up this week.
Mark
Shadowfax
Dec 19 2017, 12:48 PM
