Full Version: FS: Fuel tank, seats, brake lines
914World.com > The 914 Forums > Classified Forums > FS/WTB: 914 Parts
bixs
Everything came off a 1970 914 that was likely pieced together with parts. I no longer have the car so I'm just trying to clean out my parts surplus.
*Update: 3/10/2018 ADDED a bunch of smaller items*
1. Fuel tank, SOLD
2. Seat bracket SOLD
3. Seats SOLD
4. fuel cap SOLD
5. fuel filler neck SOLD
6. Fuel tank straps SOLD
7. Cunifer brake lines, (Product page says: Porsche 914 all except 75-76) SOLD
Service kit from AutoAtlanta (was $100) Asking $60
1. Oil filter
2. Fuel filter
3. Continental alternator belt
4. Bosch spark plugs
5. Bosch contacts
6. Bosch rotor
7. Bosch distributor cap
8. o ring for distributor
9. Ignition condensor
10. 2 cork valve cover gaskets
Victor Reinz Fuel Injector base seals and tip seals, $1 for 8 total seals SOLD
Genuine Porsche Tapered Fuel Hose for Connection at Fuel filter, 70-74 1.7/1.8/2.0 SOLD
VDO Fuel Tank sending unit gasket 1.7/1.8/2.0 (1970-76), SOLD
Victor Reinz Intake Manifold gaskets 1.7/1.8 1970-1975, $7 for 2 gaskets
Stainless Steel Tunnel Fuel Line Set (one 8mm and one 9.5mm), 914 (1970-74), SOLD
Stainless Steel Engine Compartment Fuel Line Set (NOTE: 1970-74 cars
also use tapered fuel hose 914-356-525-00-M100), 914 (1970-76), SOLD
Victor Reinz cork valve cover gaskets, $5 for 2
Fuse Kit - 911, 912, 930, 924, 928 1978-84, 944 1982-85.5 914 Fuse Assortment SOLD
Bulb Kit - Assortment $3
bdstone914
What does that tank look like inside? Outside looks pretty rusty. I would try to remove those aluminum nuts on the bottom.
bixs
icon_bump.gif Bump! I included two pictures of the inside of the gas tank and drastically reduced all prices. Prices are still negotiable.
bixs
bump!
Psw1811
I would like the brake lines if you would consider posting to the UK - PM sent
bixs
Added a lot of smaller sparts + fuel lines
QUOTE(bixs @ Dec 10 2017, 02:37 PM) *
1. Oil filter
2. Fuel filter
5. Bosch contacts
6. Bosch rotor
Genuine Porsche Tapered Fuel Hose for Connection at Fuel filter, 70-74 1.7/1.8/2.0 $10
VDO Fuel Tank sending unit gasket 1.7/1.8/2.0 (1970-76), $2
Stainless Steel Tunnel Fuel Line Set (one 8mm and one 9.5mm), 914 (1970-74), $45
also use tapered fuel hose 914-356-525-00-M100), 914 (1970-76), $25
Fuse Kit - 911, 912, 930, 924, 928 1978-84, 944 1982-85.5 914 Fuse Assortment $3
danoswork
I will take the fuel filler neck. email danoswork@aol.com re payment and shipping costs
My zip is 97224
Thanks,
Dan
koozy
Interested in the fuses
kahluver
PM Sent - I'll buy all of the fuel tank parts, fuel lines and seat brackets if available.
type47fan
PM sent
dakotaewing
Based on the ad, looks like you have 2 stainless fuel line sets.
I'd like one of the 2 sets if they are not both spoken for...
Please send me a PM -
Thanks,
Thom
cooper951
Do you have the back pad?
bixs
QUOTE(cooper951 @ Mar 13 2018, 09:38 AM) *
I do, I'm selling the full set w/ seats.
bixs
I've added some PENDING to the original post, if I don't have arrangements or PM chat with you, it's been spoken for smile.gif
Jonathan Livesay
I'll take the seats. Sending PM
Mike D.
second on the seat set. pm sent
thanks
Invision Power Board © 2001-2024 Invision Power Services, Inc.
