Full Version: 914/6 in CA
914World.com > The 914 Forums > Classified Forums > FS/WANTED: 914 Cars and Rollers
mettelman
Would appreciate any comments on the car or the seller
https://autokennel.com/1970-porsche-914-6/
Gustl
IIRC there was just a discussion about that car in another threat here on 914world ... I think it was in the garage idea.gif
you might try the search function
nine11speedster
QUOTE(mettelman @ Jan 12 2018, 05:38 PM) *
Haven’t seen the car in person. But I know the seller - AutoKennel - Paul Kramer. Good guy and trustworthy.
dr914@autoatlanta.com
there is no way this car has 53,000 miles on it unless it was the most abused 914-6 in history. Although a very nice looking car (please do not get me wrong) this car has been extensively restored, and at one time completely taken apart. However the car is well worth the asking price, if it shows as well in person as it does in the hard to see, many pictures. Here are some of the things I noticed in no particular order (and I am not commenting about things like the master cylinder reservoir cover!)
no emergency brake handle rest black rubber cover
the windshield has been replaced
has a funky rear view mirror installed
no screw drivers in the tool kit
the upper dash vinyl has been replaced and is over padded
the threshold plates have black instead of white rivets installed
the fuel lines coming up through the engine shelf are cloth instead of clear plastic
the engine stickers are incorrectly installed and some not original
the headlight box serial number plate has been previously been damaged for some reason, maybe previous wreck?? Hard to tell
the rear trunk floor has been worked and the caulking at the rear panel is not correct, maybe previous damage
the Karmann plate is a reproduction one
the car has been extensively repainted
the blaupunkt radio has a late model bezel instead of the original chrome one
the floor boards have had the original sound deadening removed and funky new sound deadening improperly installed (the original looking one piece parts are readily available)
why did they not paint the floor pan bottom green when they did all of the body work?
the center seat cushion is from a later model car (the vinyl grain does not match)
the fog light bezel is from a 73-76 car
the front shock towers have been recoated with black but should have the top nut and washer black as well
Why was the rack and pinion replaced on a 53000 mile car?
I can certainly see rebuilding the carbs and adding the carrera tensioner kit but it seems like there was just too much engine and transmission resealing and other work on the power plant for, again, such a low mile car.
mettelman
Thank you George, It's great having someone who knows these cars inside and out weigh in. I may go see it in person and get further clarity on the issues you raised.
bdstone914
QUOTE(mettelman @ Jan 15 2018, 09:11 AM) *
Yes there are many small things that are not correct. I think the fog light lenses are wrong. What I would be most concerned about is the rust that can be seen on the struts, A arms and seams of the battery tray support and other areas. How did they paint it? The struts have chips in the paint and the nuts to the tie rods are painted.Still a pretty car. For 100K I would be very pickey. At least the seller is open and informative.
PancakePorsche
Wow George I'm surprised you didn't mention the euro rear lenses and yellow fog light switch insert ! smile.gif
Nice car, nice color, new owner will be proud. Wish mine was that clean.
billsimmeth
I see that the car sold to Netherlands....
Invision Power Board © 2001-2018 Invision Power Services, Inc.
