OK, here we go.
First off, here is my original assembly. As noted, in pretty decent condition as my 914 is low mileage original in exceptionally nice shape.
Click to view attachment I am including this picture of the original as it shows something pretty important. The position of the rear cam lock in relation to the keyway slot (the wider one is at the top). If this is not properly positioned when you reassemble do not close your trunk or you may not be getting back in!
Click to view attachment Here is the inner lock barrel removed. Notice the small gasket. The gasket on mine is reusable but certainly fragile after 40+ years. This is one of the two bits that I think should be included in the kit. I reused this one.
Click to view attachmentThis photo shows the original and new inner barrel. Both new and old parts are an excellent match. The original outer has some part number markings that the new one does not but otherwise, materials and design seem pretty much identical. The instructions not that lock barrel often has a buildup of old grease and dirt. Yes, as does almost everything else. Cleaned up all the parts and oiled / greased. Even if you are keeping your originals, this is a bit of maintenance that is likely overdue.
Click to view attachmentHere is a photo of the original inner lock barrel. In step 3 of instructions it is noted that there is a small plastic seal at the top of the lock barrel and to be careful as these seals are very fragile. That black bit at around 12 o'clock in following photo is what was left of my plastic seal, it has essentially disintegrated. At first I thought it was just old grease. If mine is this bad, I imagine many others are far worse. This is the 2nd part that I do think should be part of the kit.
Click to view attachment When I went to put the lock cylinder into the inner barrel, I noticed that there was more play than there should be. That is when I realized the aforementioned seal was toast. My field expedient solution was to use an HNBR O-Ring (like used for air conditioning components). I put some grease on the o-ring as well. Seems to do the trick in eliminating the play. Again, wish the proper replacement part had been included.
Click to view attachment As noted, instructions were pretty good. Here it is back on the car. Again, before you close the trunk, push the button in and out to make sure the cam is engaging the release for the trunk.
Click to view attachment Overall, I think the final fit and finish are excellent. The instructions were easy to follow and reasonably complete. It is short of being a 10 by a gasket and a seal. I am not sure if the kit I received is final production or not, perhaps that is something Uro will address. I can not say how well the finish will hold up over time. It was only installed this evening and I only venture out with the 914 on sunny days. Still, I do not anticipate any problems.
Finally, I will reiterate that I have no affiliation with UroParts. They contacted me via the forum here and asked if I would do a review of this product which, in full transparency, they provided to me at no cost. Mostly I did it for fun and, being out of work at the moment, I have nothing better to do! I have tried to be fair and balanced in my review, highlighting both the hits and misses. Hope you all found it useful
