Full Version: Type 4 rear main seal: which kind doesn't leak as much?
98101
I'm finding contradictory information online about which kind of rear main seal I should use when we go in to fix the oil leaks. VW, Sabo? We'll be swapping the transaxle anyway, and investigating the clutch slipping. Are there any new findings about which kind doesn't leak oil?
I guess this should be called "engine to flywheel" seal instead of "rear" since it would face the front on a VW bus.
injunmort
i used an ehrling, 2 years no problems
IronHillRestorations
The only one I could find that was the correct size was Sabo, I get them from gowesty.com
saigon71
QUOTE(Perry Kiehl @ Feb 11 2018, 06:17 PM) *
After blowing a rear main on initial startup of a fresh rebuild, I researched and found that SABO seems to be "the best."
MartyYeoman
Black or orange? Which is which?
saigon71
The SABO I installed was black.
TheCabinetmaker
Sabo. Period!
DRPHIL914
QUOTE(injunmort @ Feb 11 2018, 06:06 PM) *
I am pretty sure mine is Ehrling, 4+ years now, no leaks- did this when I did full clutch job and transmission rebuild from Dr. Evil clinic-
Dr. Phil
gowesty.com has the one you want. Here's an article they wrote about the RMS
http://www.gowesty.com/tech-article-details.php?id=60
DRPHIL914
QUOTE(Perry Kiehl @ Feb 12 2018, 08:04 AM) *
interesting read Perry - so it will be interesting to see if my new RMS on the boxster will last or how long, just did the clutch and IMS , it took it in thinking I had an RMS leak but it was not leaking , it was leaking from the IMS seal , but while we did all that work the shop wanted to know if I wanted to do a new RMS since the flywheel was being replaced too- so I said yes thinking new would be better and old original will start to leak - I might be wrong depending on which seal they used! ugh. time will tell! I have no idea which brand they used- hope it was OEM or the Brazil one!
Montreal914
Just did my clutch a couple weeks ago. After reading about it on GoWesty, I ordered their Sabo.
Definitely a nice part, much larger contact surface to the engine block. Flywheel mating surface needs to be smooth.
Time will tell...
98101
Ordered. Thanks for the help.
Invision Power Board © 2001-2019 Invision Power Services, Inc.
