914Sixer
Apr 17 2018, 12:21 PM
Just got shipping notice that my heads are on the way.
They will be here Friday. Should have some pictures for the weekend.
nditiz1
Apr 17 2018, 12:27 PM
QUOTE(914Sixer @ Apr 17 2018, 10:21 AM)
Mine too, super excited!
rgolia
Apr 17 2018, 02:14 PM
I think mine are next up. Let me know how they look when you get them. Starting to get excited but still lots of work to do before the 914 hits the pavement.
Mueller
Apr 18 2018, 07:25 PM
Congrats....I came pretty close to ordering a set , however the $ added up quickly since I have a 1.8 which I figured the cylinders would be too small so I'd have to invest (buy) 2.0 P/Cs and then buy a 2.0 crank w/rods.
nditiz1
Apr 19 2018, 07:44 PM
gothspeed
Apr 19 2018, 08:03 PM
Awesome!!! What size intake/exhaust valves are those?
914Sixer
Apr 19 2018, 08:32 PM
Nick got his 1st. I just noticed there is not any studs in the head. Going to have to find new ones for the exhaust, intake and rockers. Going to have to check out Bel-Metric.
nditiz1
Apr 19 2018, 08:43 PM
Stock 2.0 valve size 42x36
Mark - Len included a stud kit and a block off for venting or a vent tube if you want to go that route.
Dave_Darling
Apr 20 2018, 12:14 AM
QUOTE(Mueller @ Apr 18 2018, 06:25 PM)
I have a 1.8 which I figured the cylinders would be too small ...
The 1.8 cylinders and the 2.0 cylinders have the same OD. The ID is only 1mm different, too. You could have used them, though I don't know how different the combustion chamber sizes are, which could have a huge effect on the compression ratio. And you'd have to deal with the intake and engine tin and such.
--DD
jcd914
Apr 20 2018, 12:52 AM
Per the factory spec book:
1.7 heads have 51.1cc to 52.6cc combustion chambers.
1.8 heads have 52cc to 53.5cc combustion chambers.
2.0 heads have 58.7cc to 60.2cc combustion chambers.
So with a stock 1.8 bottom end and stock 2.0 heads, the compression would drop significantly.
Jim
914Sixer
Apr 20 2018, 05:48 AM
Great the studs are there just not installed.
Apr 20 2018, 05:52 AM
QUOTE(914Sixer @ Apr 20 2018, 07:48 AM)
Much safer to ship without studs installed.
barefoot
Apr 20 2018, 07:10 AM
Are the chambers ceramic coated ??
Looks great !
malcolm2
Apr 20 2018, 07:23 AM
QUOTE(Mueller @ Apr 18 2018, 08:25 PM)
I started with a 1.8 and just upped the P/C to 96mm IIRC, kept the 66mm crank and 1.8 rods.... 1911cc with 2.0 heads. Or in my case the valves are 2.0 size. I like mine. Saved me alittle $.
HAM Inc
Apr 20 2018, 08:11 AM
I'm very pleased that everyone in the GB went with the ceramic coating. There is still much that's unknown about these Chinese castings, and with what we know about the more sturdy AMC castings and the benefits of ceramic in protecting them I feel it was imperative with the AAP's.
One thing to keep in mind about the ceramic coating, it's extremely chemical and heat resistant, but it is not at all abrasion resistant. It scratches and scuffs very easily, so be careful with sharp objects, and if you want it stay pretty don't touch it with oily fingers. It stains easily, though the stains do no harm.
914work
Apr 20 2018, 08:28 AM
QUOTE(malcolm2 @ Apr 20 2018, 06:23 AM)
You'll like that combo match it with 2.0L exhaust !!
914Sixer
Apr 20 2018, 02:52 PM
Got mine this afternoon. Really nice. Thanks Len.
HAM Inc
Apr 21 2018, 08:39 AM
You're welcome Mark. Hope everyone is happy with their heads. I expect the last of them back from the coater in the next week or so.
ClayPerrine
Apr 21 2018, 11:13 AM
QUOTE(jcd914 @ Apr 20 2018, 01:52 AM)
Jim
Stock 2.0L crank and rods with 1.8L heads makes for a bump in the compression ratio. Put 2.0 valves in the 1.8 heads, and you make up for the non-optimal plug location issues with the increase in compression. Plus the 1.8L heads don't drop valve seats like the 2.0L heads.
If you do it, make sure you run premium gas all the time.
Jetsetsurfshop
Aug 2 2018, 03:44 PM
I did a set too .
Thanks Len!!
HAM Inc
Aug 2 2018, 05:23 PM
Shane's going to help us gather some serious real world survival data on these heads. He's using them on a ChumpCar 914 that will be beat on by rent a ride racers!
Notice the full compliment of coatings!
Hang ten, Shane.
914_teener
Aug 2 2018, 05:41 PM
I see Len is on to the benefits of entropic ceramic coatings.
Beautiful work Len.
nditiz1
Aug 3 2018, 08:08 AM
Just wanted to add my experience so far with these AA Piston heads. They seem to be holding up well. I only have 500 miles or so on them, but have peaked ~390 head temps on #3 a few times up hill and a recheck of the valves has shown no adjustment needed.
I also went with the bus 10mm swivel adjusters on them.
I'll report back more once I get my carbs jetted correctly.
Beakster
Aug 9 2018, 12:23 PM
What Kinda $$$ money did these cost ?? Are they Brand New or just yours redone ??
nditiz1
Aug 9 2018, 12:45 PM
The Group Buy was $1275. With Ceramic coating then went up to $1500. Total was $1539 shipped to me.
Now these are the same NEW 2.0 heads from AA Pistons, but with Len Hoffmans full rework.
Mine are holding up well.
Jetsetsurfshop
Aug 9 2018, 01:53 PM
20 minutes on mine so far
ChrisFoley
Aug 10 2018, 06:35 AM
QUOTE(Jetsetsurfshop @ Aug 9 2018, 03:53 PM)
Same with Ralph's engine.
