QUOTE(djway @ May 16 2018, 04:57 PM)
Cerium oxide to polish out fine scratches. Deep scratches can be done, I have done it, and it is a TON of work.
I did an early Ghia that had very bad scratches everywhere. I tried all sorts of materials, some made things worse but I did find a working solution.
6 inch pad with wet/dry paper, the starting grit depending on how deep the scratch is. You must have water running over the glass at all times to keep the temp down. As with anything you keep going to finer and finer grits and then you finish off with the cerium oxide.
You must pull the glass and set up a table with the set water supply. It is a lot of work.
My Ghia glass is very rare and expensive so it was worth the hundreds hours invested.
Good luck
I've watched a few vids on the deep scratch repair. My take away was that in addition to the tools you show, you also need to have a large pair of balls.
So when you say wet/dry paper, you are talking just regular wet/dry abrasive paper? Not some special diamond grit at $80/ pad? Also, what did you mount them on? All the vids show high speed drills or grinders which surprised me, and the pros were grinding dry which also surprised me.
I think I'll try the milder methods of steel wool and cerium first and evaluate. If they need more, I'll see what the local glass shops say about it If need be, I have spare glass with at least one humdinger of a scratch to practice on first. My motto is: "Fail Spectacularly!" Hoka hey!
