Mueller
May 15 2018, 02:47 PM
Just pulled the plug and bought this kit yesterday.
4 preset curves via dip switches. Don't like those and you can use your laptop to make custom curves and a 3D map.
I didn't get in on the 123Ignition group buy and stumbled upon this setup.
As a plus it comes with wires and a new coil and can be used with
boost.
$360.
I'm using L-Jet for fuel and it'll fire the injectors when the coil collapses just like a stock distributor.
https://www.cbperformance.com/product-p/2016.htmClick to view attachment
porschetub
May 15 2018, 03:06 PM
Nice to see another option out there,will the unit clear the engine tin on a T4?,how do the vacuum pickups work? I see 4 of them?.
Should be a good unit,good luck with it.
Beebo Kanelle
May 15 2018, 03:25 PM
Good Info, thanks
Amphicar770
May 15 2018, 04:50 PM
This on their web site. ...
NOTE: MAGNASPARK II & MAGNASPARK Digital will not fit T-3 or T-4, without modification the engine tin. Resistor spark plugs are required.
Bosch Blue Coils are NOT compatible.
Mueller
May 15 2018, 05:23 PM
QUOTE(Amphicar770 @ May 15 2018, 03:50 PM)
About same mods as if installing a Mallory or MSD distributor, no big deal.
McMark
May 16 2018, 10:57 AM
The old Mallory was a drop in. But regardless, you're right, it's no big deal.
michael7810
May 16 2018, 12:27 PM
QUOTE(Mueller @ May 15 2018, 04:23 PM)
Can you post a pic of the tin mod? This looks interesting...
rhodyguy
May 16 2018, 01:27 PM
All you is give the tin a med sized dimple where it interferes with the larger distributor body. Easiest to locate the spot when you try to slip the larger dist in. I think I used a hardwood dowel and a hammer.
jim_hoyland
Sep 3 2018, 05:53 AM
Tomorrow, I'm meeting with my local indy who has serviced my 914 the past 20 years. I'm hoping he can troubleshoot the Mallory Unilite. If he can't, I'm going to consider Plan B
I'm not very mechanical on the ignition system; but a friend came over to trouble shoot the system. He though the coil produced a very wet spark; even a back-up coil appeared weak. After we replaced the Mallory optical module, it started right up; the next day, I started the car to idle in the garage and after 5 minutes it died. Won't restart like before.
So, I'm also thinking there is something else going on; gonna know more next week
