QUOTE(billh1963 @ Sep 21 2018, 05:06 AM)
QUOTE(euro911 @ Sep 20 2018, 09:43 PM)
It
IS a great little wheel if you want quick steering response in the twisties
How's the 'BB' coming along, Bill ?
Pretty good! I think the carbs need to be rebuilt (as we discussed when I bought the car). The carbs popping at idle and at low driving RPM indicate a lean condition. The idle jets look like they are 50's (not 60's) so I might go up a size to 55 before I rebuild the carbs. I did pull all the jets and cleaned them with carb cleaner but it made no difference.
So far I have:
Installed the ignition switch
Fixed the turn signal/emergency flashers
Replaced the steering wheel with an original one (horn works, by the way
Replaced the rubber where the windows meet the targa bar (the ones on there were cracked)
Installed a Camp914 strut kit on the rear trunk lid
Fixed the interior passenger door handle
Compounded, polished and waxed the whole car
Next steps are:
Adjust the valves for zero lash (will do that before I mess with the carbs) just to make sure
Get the ATS wheels powder coated
Drive the snot out of it
Great. In case you haven't found them yet, I think I put the carb rebuild kits in the center armrest box - in a small unmarked white box.
I didn't have an idle popping issue out here, at least not after reaching full operating temperature. I never got the chance to check the AFR after installing 32mm venturies and rejetting the carbs ... I misplaced a suitcase with all my automotive diagnostic gear a few years ago - looked
almost everywhere here, then thought I may have taken to AZ, but nope not there either. My wife found the suitcase a few weeks ago, buried up in the attic
Were the air horns a surprise? ... people aren't expecting that much noise out of a little car and it sure wakes them up
Post some pix when you get a chance - really like to see it all dressed up
