dr914@autoatlanta.com
Sep 13 2018, 10:58 AM
We now have factory look gauges to fit in the center console. These are the exact original factory size and are complete with the rubber gasket. 35.00 each
volt meter, oil temperature, and oil pressure
Click to view attachment Click to view attachment
PatrickB
Sep 13 2018, 12:20 PM
Nice! Now I'm torn... I have a smaller set on order so I can make room for a pyrometer and boost gauge...existing temp and volts working with my diesel. Oil pressure replacing the clock would be cool if I didn't want room for more.
yellowporky
Sep 13 2018, 01:21 PM
Do you have the rubber gasket available separately?
Thanks
Chris
Sep 13 2018, 03:41 PM
yes Chris.
We also have the smaller oil pressure gauge available for tight applications such as in the dash face for some of you racers
QUOTE(yellowporky @ Sep 13 2018, 12:21 PM)
Thanks
Chris
Larmo63
Sep 13 2018, 11:58 PM
I ordered, oops, I had to have my girlfriend order, a "NOS" fuel/brake light gauge from you. It arrived and was a POS. Dirty, scratched bezel, remember, you took her call. (you hung up on me) You sent a replacement eventually, but I swear I will NEVER buy anything from you as long as I live.
(Rant over.)
Wait, the reason you hung up on me is, because I had a prior BAD transaction with you; you sent a different part before that you wouldn't replace and I had to finally resort to negative feedback on eBay.
Buyer beware.
YMMV.
rgalla9146
Sep 14 2018, 05:51 AM
Can we all put a headline in the Garage section every time we list a part in the
Classified ?
PanelBilly
Sep 14 2018, 08:25 AM
Finely! I tried to order one from Northhollywood and it was going to cost TOO MUCH. My order will go in this weekend. These are the 60mm size?
Sep 14 2018, 09:02 AM
yes the 60 mm sized gauges. Brutus the 916 has one installed on the aux console
QUOTE(PanelBilly @ Sep 14 2018, 07:25 AM)
