Steve
Oct 14 2018, 04:19 PM
My 75 came with a rear PORSCHE reflector. I would like to go back to stock. What is the best way to plug the giant holes? Replace the whole rear panel?
Thanks in advance for the help!!
IronHillRestorations
Oct 14 2018, 04:32 PM
Restoration Design makes new tail panels, but I found a design flaw in one I got. I sectioned the new panel into the old and it turned out to be a lot of work. I don't know if replacing the entire piece would've been easier.
A real NOS part will always be best, but good luck finding one. Next option would be sectioning in a good salvage piece.
914xr75
Oct 14 2018, 05:01 PM
I had a Local welder in Orange County California come out and add a plate to the back and fill in the holes. He charged me $150. I can give you a referral to him. I think the best way to go is to have a welder fill them in without a backing plate. My car is not a show car so I didn't mind.
Oct 14 2018, 05:11 PM
A good welder can fill the holes and make them invisable. No patch panel needed. Had it done on mine.
Steve
Oct 14 2018, 07:11 PM
Thanks for the help!! I know a couple of good welders. I will look into it.
Costa05
Oct 14 2018, 09:57 PM
Should be able to fill them in easily with a mig welder. I have filled in 1/4" holes already just by doing light zaps at the edges until you close the hole up. Then take an angle grinder to it to flatten it down.
sixnotfour
Oct 15 2018, 04:28 AM
I just drilled more
dr914@autoatlanta.com
Oct 15 2018, 09:19 AM
by all means just weld up the stud holes DO NOT cut the body apart!!!
QUOTE(Steve @ Oct 14 2018, 03:19 PM)
Mikey914
Oct 15 2018, 10:47 AM
Simple process to weld them up. But before you do. Check inside the trunk to make user there is not a reason to dig into the welds (rust), if you have to, then no point in patching holes on a part you will replace. Unless to just drive it.
horizontally-opposed
Oct 15 2018, 10:52 AM
QUOTE(mepstein @ Oct 14 2018, 04:11 PM)
^ Likewise. Had the same done with the last paint job with no patch panel, and you can't tell the car ever had a PORSCHE reflector. Wasn't a lot of money in the scheme of things, particularly since we were doing the whole car. For those who aren't, the nice thing about that panel is that it's "topped" by the trunk lid, "sided" by the taillights, and "edged" at the bottom (and then what's below that is nearly covered by the bumper top)—so it's about as easy as blends get.
cary
Oct 15 2018, 01:56 PM
Easy deal. Just go slow in a criss cross pattern. Try to keep the heat
down to minimize the amount of filler that would be needed.
Use a nice smooth copper or brass backer.
Once you've gone around and made the complete circle. Use a small grinder if you have one to flatten it out so you don't start
welding up a cone. That will keep you from having pock mark on the backside. And a thin spot on top.
ValcoOscar
Oct 15 2018, 02:25 PM
QUOTE(cary @ Oct 15 2018, 12:56 PM)
with Cary....and take your time.
Steve...I know you like South OC but come up to NORTH OC and we can tackle this for you as a mini tech day. Don't mind the grinding dust. Price is right
Oscar
Steve
Oct 15 2018, 08:48 PM
QUOTE(ValcoOscar @ Oct 15 2018, 01:25 PM)
Oscar
That would be awesome!! Week day or weekend? I need to get my car running first.
ValcoOscar
Oct 16 2018, 08:20 AM
QUOTE(Steve @ Oct 15 2018, 07:48 PM)
porschetub
Oct 16 2018, 10:11 PM
Crank the amps and wire feed down get a nicely wet towel rag and stitch away small beads @ a time and cool them,take your time and you will have limited cleanup work with a flapper wheel.
Nice to see another one of these gone from the rear of a 914
ValcoOscar
Oct 16 2018, 10:20 PM
Back in the late 80's I had one on my V8 914. NO MO
Oscar
sixnotfour
Oct 17 2018, 05:09 AM
great plate
Oct 17 2018, 06:19 AM
Me 2
ValcoOscar
Oct 18 2018, 10:10 AM
I just cut this panel for you to practice on....
I'll be ready when you are!!!!
Oscar
Steve
Oct 18 2018, 02:07 PM
QUOTE(ValcoOscar @ Oct 18 2018, 09:10 AM)
Oscar
Click to view attachmentNice!!! Tnx!!!
Steve
Oct 28 2018, 03:39 PM
Oscar
Click to view attachmentI got my car running today!! Do we want to plan a welder work party for those that want to dump there rear reflector?
@ValcoOscar
914 RZ-1
Oct 28 2018, 04:06 PM
Another option if you don't mind a cosmetic blemish on the inside where no one will see it unless they are looking is to cut small pieces of steel and use JB Weld to plug and fill the holes. Use the small piece of metal as a backing. The JB Weld sands really nice. Just put a little body filler in any place where the JB Weld didn't fill, sand and prime.
No welding required! This is what I did because I don't have any welding friends close by.
ValcoOscar
Oct 28 2018, 06:18 PM
QUOTE(Steve @ Oct 28 2018, 02:39 PM)
Oscar
@ValcoOscarGlad it's back on the road. Let's discuss next Sat at 914 cone zone to set date...but it's a GO
It will be quick and easy.
Oscar
ValcoOscar
Nov 7 2018, 08:46 AM
SoCal Mini tech day
@ My house 90621
Sunday Nov 11th 8AM-10AM
Welding up some rear panel holes for Steve and Jerry.
Spectators welcome
@Steve
@LS1V8Jerry
@Nacho
Oscar
Steve
Nov 7 2018, 08:48 AM
Awesome!! Thanks!!
sb914
Nov 7 2018, 08:53 AM
Steve
Nov 7 2018, 09:03 AM
QUOTE(sb914 @ Nov 7 2018, 07:53 AM)
Our thoughts and prayers that they fix everything and for a “speedy” recovery!!
Nacho
Nov 7 2018, 08:28 PM
I'll try my best to make it but I've been battling a bad cold. Hopefully my meds cure this darn thing before then.
ValcoOscar
Nov 8 2018, 10:31 AM
You two boys get better, Eddy
@SB914 we got your back. Nacho
@Nacho hope you get better.
@SO.O.C914er is joining us.
Oscar
Spoke
Nov 8 2018, 12:32 PM
I cut little hex disks out of 18 ga steel and welded them in.
SO.O.C914er
Nov 8 2018, 01:03 PM
Hey Oscar I plan on showing up as well should be a good time. I’ve got a few minor things to do. I could do them in my garage but would have a much better time with the group......thanks Paul
ValcoOscar
Nov 11 2018, 05:49 PM
Had a great day...got Steve welding. Bob from Seal Beach also joined us as well as Paul, Jerry and Bob.
All sealed up...ready for final prep and paint.
Good job Steve
Thanks again for lunch Steve
Till next time...
Oscar
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=674
564]
ValcoOscar
Nov 11 2018, 05:50 PM
Get well Nacho and Eddy...
SO.O.C914er
Nov 11 2018, 07:35 PM
Great workmanship guys that cleaned up nice!
Steve
Nov 11 2018, 09:01 PM
Awesome day!!! Thanks Oscar, Jerry and Bob for the welding and body work tutorial.
Thanks Paul for dropping by, good to see everyone!! I took a bunch of notes and pictures. You guys make it look so easy. I will be less afraid to tackle this on my own next time!!
You guys rock!!!
