Chi-town
Oct 19 2018, 03:34 PM
Koni "Special D" rear shocks complete w/ top hats but no springs $75 SOLD!
Green "no name" springs for rear $25 (I don't know the rate, were in a V8 conversion) SOLD!
Stock rear trailing arms $65
Stock rear calipers with brand new pads $150 SOLD
Stock front calipers $75 (in good shape but need cleaned)
Front and rear shift rods w/ front under shifter joint, center u-joint, and rear connector for side shift $50 SOLD
Rear 5 lug re-drilled rotors - $30 (smooth but could use resurface)
Stock 914-4 Hubs and stubs w/ nuts and washers & rotors $40
Metal Expansion tank $20 (in good shape but will need repaint)
Filler neck $20 (in good shape but will need repaint)
Gas Tank strap assembly (Both Straps, bolt / T-nut, plastic piece) $20 SOLD!
PM me an email address for pics.
I'm in Anaheim, CA for local pick up
I will ship on your dime.
Add 3% for PayPal fees
Edit: Lower prices
Nacho
Oct 19 2018, 03:49 PM
PM sent
Chi-town
Oct 22 2018, 12:41 PM
Bump for lower prices!
914Sixer
Oct 23 2018, 03:57 AM
Do you have the top nuts and spring holders for the Koni shocks?
Chi-town
Oct 23 2018, 10:47 AM
QUOTE(914Sixer @ Oct 23 2018, 02:57 AM)
Yes, I have the lower perch, and the complete top hat assemble (spring hat, big washer, long nut, bushings, small washer, small nut)
Chi-town
Oct 30 2018, 01:23 PM
Bump! If you're interested make me an offer!
914dream
Nov 5 2018, 09:10 PM
The stock 914 hubs...are they the earlier hubs of consistent thickness? I understand they’re better for redrilling for five lugs? Or am I misinformed?
Thanks!
Retroracer
Nov 6 2018, 02:55 PM
Could you post or PM a pic of the springs pls?
- Tony
infraredcalvin
Nov 7 2018, 09:09 PM
Local buyer, Are the 5 lug redrilled rotors fronts or rears? Pic please... thanks!
Chi-town
Nov 7 2018, 10:17 PM
@914dream - they are stock hubs, there is no advantage to the early hubs with the extra bosses for the 5 lug conversion unless you're racing the car and then you should go to the 911 hubs.
@infraredcalvin - they are rear
@Retroracer
infraredcalvin
Nov 7 2018, 10:41 PM
Thanks, was looking for fronts.
Chris914n6
Nov 8 2018, 01:20 AM
2nd dibs on the rear springs.
Retroracer
Nov 8 2018, 01:24 PM
PM sent re: springs
- Tony
Chi-town
Nov 27 2018, 01:52 PM
Bump! Still cleaning up before I part out the 75'!
