When installing the 3 aluminum trim pieces on roll bar, are the 2 side trim pieces the only support for the top roll bare piece. The reason I’m asking is on my previous 914 I thought there was a clip in the center of the trim piece that fit in a hole in the bar to hold it in place. Thanks
toolguy
Nov 1 2018, 11:28 AM
the horizontal center bar should have 3 clips that secure it to the rollbar frame at the pinch weld seam
Nov 1 2018, 11:51 AM
Those 3 trim clips hold it very secure. It takes a pretty good tug to remove.
xperu
Nov 1 2018, 12:34 PM
That’s what I thought. My car has no holes. Maybe covers during body work. I”ll start a search and find. Thanks guys. Mike
Nov 1 2018, 01:07 PM
QUOTE(xperu @ Nov 1 2018, 02:34 PM)
No holes. They clip on to the seam.
xperu
Nov 1 2018, 01:19 PM
QUOTE(mepstein @ Nov 1 2018, 02:07 PM)
OK Mark, I've had these off for about 10 years and could not remember, I will have to do a search and find some. Thanks Mike
Nov 1 2018, 01:27 PM
part # 914.559.223.10
About $10 each at the porsche dealer but you can probably find used. Maybe bdstone, Garold, ect
OK so now that I picked up the 3 clips, What is the best method to install. I looked at several threads, but no info. Like I said before it's been 10 years or so sense I removed the trim and really can't remember. I just do not want to screw things up. Thanks Mike
Nov 8 2018, 02:49 PM
QUOTE(xperu @ Nov 8 2018, 03:26 PM)
QUOTE(mepstein @ Nov 1 2018, 01:27 PM)
Clip goes on the trim then push trim onto targa bar. Push straight on, it doesn’t slide on from the side.
dr914@autoatlanta.com
Nov 8 2018, 02:51 PM
PLENTY on the shelf, and we have used as well
QUOTE(Chi-town @ Nov 1 2018, 12:28 PM)
Anyone sell those three clips? Mine are missing also
xperu
Nov 8 2018, 03:37 PM
QUOTE(mepstein @ Nov 8 2018, 02:49 PM)
Thanks Mark, ur always a big help. Thanks again. Mike
rgalla9146
Nov 9 2018, 01:03 PM
Just to clarify...The clips are slid into the horizontal aluminum trim then the piece is pushed onto the pinch weld.
Nov 9 2018, 01:15 PM
yes three clips slide into the aluminum trim and then the trim is clipped to the roll bar, then the end pieces are installed
QUOTE(rgalla9146 @ Nov 9 2018, 12:03 PM)
