Full Version: THE COLONEL Questions!
Stoddy
Hello folks,
I've a couple of questions that I've thought of whilst sipping tea and dismantling the Colonel.
Is it wise, common practice, adviseable, to replace the original wiring? or, should I test it and then put it back if it all works?
Are there any other parts which should be replaced, period? like relays, things like that?
And finally, for now, the petrol tank....whats the best way to re condition that? looks quite cruddy in there, but very little rust seems to be present on either the outside, or the inside. I removed a couple of litres of VERY stinky old fuel already.
Thanks in advance!
914Sixer
New tanks available from J P Dansk, cheap in the UK. Try 911Ltd.com. No new wiring harnesses available. Some relays available but check fitment. Not always listed correctly
Cairo94507
You could buy a new tank, or depending upon the cost, take your tank to a radiator shop to have it boiled out and see what condition it is in. Then check into having the inside coated to protect it and refinish the outside like new. beerchug.gif
Like sixer said - there are no new harnesses available so repair and restore as needed.
Jonathan Livesay
QUOTE(mepstein @ Feb 10 2019, 07:19 AM) *
These guys list one for 914/6
https://www.ynzyesterdaysparts.com/catalog/
altitude411
Is Jeff not doing harness/harness repair any longer? confused24.gif
http://bowlsby.net/914/WiringHarnesses/
Nobody makes a 914-4 chassis harness.
Matty900
QUOTE(altitude411 @ Feb 10 2019, 09:00 AM) *
There are about 72 different variables for a main wiring harness depending on year and options. Jeff is your man for this.
bbrock
echocanyons
Try this guy looks like he does excellent work but no personal experience
Kroonwireharnesses.com
Stoddy
Thanks gents, I'll check out the local radiator shop and take it from there.
It's best to remove the harness completely i'm guessing, when I do a full shell respray?
falcor75
QUOTE(echocanyons @ Feb 10 2019, 08:02 PM) *
Kroon only does the -6 harnesses because he cant get the -4 specific connectors in quantities less than 1000 pieces. (-6 connectors are the same as 911)
Ninehundredfourteen
QUOTE(Stoddy @ Feb 11 2019, 04:51 AM) *
Hi Rich there isa classic car wiring and harness supplies in tenbury wells ask to speak to Mattthew Blake.01584 819552
Stoddy
QUOTE(Ninehundredfourteen @ Feb 11 2019, 06:38 AM) *
Brilliant! Thanks so much.
Jonathan Livesay
QUOTE(Stoddy @ Feb 11 2019, 02:51 AM) *
If you want it to look like a 100% new car then yes. However a used harness is even harder to put back than a new one because it's a lot stiffer and more brittle. Unless you're going for a 100 point car you can get a good look by bagging the rear wiring at the firewall and the front wiring in the bottom of the gas tank well.
Stoddy
QUOTE(Jonathan Livesay @ Feb 11 2019, 05:28 PM) *
Thanks Jonathan, I think I'll test the harness, then leave it in situ like you suggest.I remember re shelling an MGBGT and the harness was a complete pig to get back in.
Thanks for the tip!
914_teener
So curious....why the Colonel?
As in Klink?
Stoddy
QUOTE(914_teener @ Feb 12 2019, 12:46 AM) *
As in Klink?
My wife came up with it as he was being pushed off the trailer, I didn't argue as it sort of just happened. I've named all my Porsches since my Gorgeous 944 Cabriolet. (Miller),
Curiously they've all been boys?!
Invision Power Board © 2001-2024 Invision Power Services, Inc.
