QUOTE(914Sixer @ Mar 21 2019, 05:30 AM)
Check 914Rubber for door panels.
I did and the panels they sent out don't fit (too thick with all the material build up wrapped around the plastic backing panels.) Can't close the door. Am looking to get them returned at this time. My originals popped right in no problem, which is why I am looking for an old stock set instead. the original panels have a relief at the panel edge and te material is not nearly as thick when bent around the panel. In fat my only problem with my current panels is that the PO cut speaker holes in them. Other that that they are perfectly fine.
