Pdr1787
Apr 2 2019, 12:15 AM
Here are a bunch of misc. parts for sale. for asking price or better offer
Spark plug wires 8mm ...... 60
*Sold* Original belt restraints ( non retractable )...... 50 *Sold*
Rocker-arm hardware (Shaft/springs/nuts/bolts/washers)...... 50
*Sold* Outside door handle ..... 50 *Sold*
Speaker cover and speaker ( Driver and Passenger side) ...... 100
Heat exchanger elbow .... 50
Heater control valve flap box ....... 50
Clutch release bearing and fork ...... 150
70-72 complete linkage 80
*Sold* Sideshift linkage rod firewall to transmission...... 150 *Sold*
Heater blower fan assembly..... 70
70-72 engine motor mount cross bar...... 50
Foot well foam insert ....... 35
Arm rest pocket and lid cover....... 50
Valve cover pair ........ 60
Shifter assembly ...... 100
*Sold* Shift rod coupler 73-76..... 60 w/bolt/screw.....80 *Sold*
Motor support bracket 70-72........ 50
Motor mounts...... pair 40
Clutch cable deflection roller and reverse bracket.......40
*Sold* 2.0l cylinders 4 ............ 180 *Sold*
Thermostat...... 80
1.7l ecu Works ....... 80
1.7 rods .... 40
Bosch 1.7distributor with vacuum advance..... 100
Hydraulic lifters 1.7 ......80
Vacuum pressure regulator ...... 80
Porsche valve springs full set 90110590150 ...... 140
Bosch starter .......... 140
Bosch 12volt coil ......50
Bosch 009 chrome .........90
Chi-town
Apr 2 2019, 12:56 AM
Open to offers? I could always use a spare 73-76 shift rod rear section.
Pdr1787
Apr 2 2019, 12:25 PM
Pdr1787
Apr 4 2019, 12:47 PM
Bump
racingredsc
Apr 12 2019, 10:54 AM
What do the heads fit? I need some for '74 2.0.
forrestkhaag
Apr 13 2019, 09:06 AM
Are the speakers spoken for? And, what condition are they in? cracks /missing pieces, etc? I would offer 60 bucks if they are decent./ please pm me if that works out /
cheers
Pdr1787
Apr 13 2019, 10:06 PM
QUOTE(racingredsc @ Apr 12 2019, 09:54 AM)
Heads are 2.0L heads. There is damage to one exhaust stud just so you know.
Pdr1787
Apr 13 2019, 10:09 PM
QUOTE(forrestkhaag @ Apr 13 2019, 08:06 AM)
cheers
The actual speakers are in good condition, fairly new. The speaker grills just need to be cleaned and i can post a picture tomorrow after i clean the up. There is a small crack in one of the corners for one grill. will post picture tomorrow
rasam
Apr 14 2019, 12:26 AM
PM sent for the thermostat.
Pdr1787
Apr 15 2019, 05:57 AM
QUOTE(Pdr1787 @ Apr 13 2019, 09:06 PM)
Pdr1787
Apr 15 2019, 05:58 AM
Pdr1787
Apr 15 2019, 06:00 AM
QUOTE(Pdr1787 @ Apr 13 2019, 09:09 PM)
cheers
Pdr1787
Apr 15 2019, 06:01 AM
cheers
Pdr1787
Apr 15 2019, 06:02 AM
Here a closer picture of the door handle
racingredsc
Apr 16 2019, 12:29 PM
I'll take the heads if the only problem is the one stud.
carl k
Apr 16 2019, 12:47 PM
Are those modified 1.7/1.8 heads? I see the four studs for the intake manifold.
Pdr1787
Apr 16 2019, 02:35 PM
QUOTE(carl k @ Apr 16 2019, 11:47 AM)
They were bored out
Pdr1787
Apr 24 2019, 04:06 PM
Bump
bdstone914
Apr 27 2019, 08:52 AM
QUOTE(Pdr1787 @ Apr 16 2019, 01:35 PM)
They were bored out
That does not make them 2.0 heads. Will not fit 2.0 runners. Might he good heads. What are the valve sizes? 1.7, 1.8 and 2.0 all use different size valves.
Chi-town
Apr 27 2019, 11:09 PM
They're 2.0 bus heads
dl5494
May 1 2019, 07:26 AM
interested in the release bearing and fork as well as the clutch reflector and bracket. also need the speed drive gear and housing that goes into the trans. (have the right angle drive already).
The side shift linkage fwd., aft and connectors as well as the ball socket for the aft trans. shifter.
thank you
dave.lanave@yahoo.com
Dutchy4U
May 1 2019, 07:00 PM
I need cooling fan wheel in pic
are all vins there / cracks ?
shoot me a $ ?
working on a 914 1974 2.0 ltr
dan123
May 15 2019, 08:16 AM
how much for the cooling fan?
also, can you pls post a pic of the front of it. thx
