mzapisek
Apr 10 2019, 08:00 AM
I'm running 245/50/16 on the back and 225/55/16 fronts with GT steel flares. Tires look good and perform well. I do get rubbing on the inner fender well at full lock. I am using a 1/2" spacer in the front.
I have a spare set of 16" front wheels. If I go with 205/55/16 to reduce the section width the tire diameter reduces by almost one inch to 24.9". My current set up has almost identical tire diameters at 25.7".
Is there a problem with running smaller diameter tires in the front? Handling? Alignment? Would this create to much rake?
Appreciate some input. I searched but couldn't find a definitive answer.
Thanks.
dr914@autoatlanta.com
Apr 10 2019, 08:03 AM
I would go with the narrower diameter, makes turn in better and actually makes the handling better as a result (also the steering is lighter)
QUOTE(mzapisek @ Apr 10 2019, 07:00 AM)
Thanks.
roblav1
Apr 10 2019, 07:30 PM
Personally, I'd go with narrower fronts, as George said. Lowering of the front by 0.8" will slightly increase rake, decrease caster, and generally contribute to more oversteer. You don't say what your current spring rates are or front and rear ride heights (or ARBs). If you're happy with the way the car currently handles, lower the rear slightly (if adjustable spring perches) or raise the front at the torsion bars.
IMHO, 205 front and 225 rear aspect ratio is right for flared 914. And 15" wheels are better than 16" wheels because of the lower rotating mass. Wider tires don't necessarily equate to better grip. Other factors play in the mix, particularly tire compound. The 914 is so lightweight anyway... they don't need the bigger tire sizes.
If you eventually swap out tires / rims, here's a general methodology for car setup:
- Set tire pressures
- Set ride height / rake
- Set corner weights
- Set caster and camber (I prefer more front caster in 914 / early 911)
- Re-check corner weights
- Set toe
- Re-attach adjustable ARB links
mzapisek
Apr 11 2019, 08:32 AM
George/Rob I appreciate the input. I have ordered the new tires and look forward to trying them out. Thanks.
larryM
Apr 16 2019, 10:46 PM
you don't tell us what ET or backspace your wheels are - or what brand
- nobody can give you a credible tire recommend without that info
check fitments yourself here
http://www.rimsntires.com/specspro.jsp
Dougal Cawley
Apr 18 2019, 08:34 AM
mzapisek
Apr 18 2019, 08:39 AM
Wheels are Fuchs standard 911 offset. Went with the 205's up front. Much lighter steering feel and eliminated the rubbing. Very happy. Thanks for the input.
Rleog
Apr 19 2019, 07:50 AM
Hmmmmm
Nice tread pattern. Pirelli’s?
Dougal Cawley
Apr 23 2019, 06:09 AM
QUOTE(Rleog @ Apr 19 2019, 02:50 PM)
Hmmmmm
they look cool, but also handle better with an older car as well.
Have a look at this thread
https://www.lamborghinichat.com/forum/threa....508651/page-16
burton73
Apr 23 2019, 04:52 PM
Your tire size is fine for the front. You just add a part from Elephant called “Tire Rub Prevention Kit”
https://www.elephantracing.com/suspension/9...prevention-kit/This will stop the wheel from turning too much when you turn the wheel all the way. Really you only go that way when you are parking or moving it
I have one on number 41
Bob B
