The pump runs when the ignition is turned off or only when hot? There is a relay on the relay panel in the engine compartment. Could that be sticking?
I don't recall of any relay or fuse on the fuse panel under the dash board.
QUOTE(Mowog4 @ Apr 19 2019, 10:09 AM)
I have a problem with my fuel pump, if I turn the ignition on the fuel pump runs and doesn’t turn off. It used to run for a second to build pressure, them turm off. Any thoughts?
Thanks
Ed
