SOLD_ Deposit received!! Thanks San
Sadly, I have decided to pass along this project to someone that can complete it. I have had it nearly 20 years in the back corner of the shop, so it is time for someone else to take ownership.
It is a numbers matching car/engine with 43k miles, that is totally apart (you will see from the pictures). I purchased it this way and I think the car may have been apart since the 80's.
Besides paint, the body is in need of some metal work. The passenger side sail panel and door jamb need to be replaced (new panels for both are included). The passenger side front fender has been hit near the door, pulled back out, but not repaired. The passenger side rear fender looks to have been replaced at some point. It is a very good repair, but the weld seam can be seen in the area under where the bumper would mount. The longs & hell-hole look pretty good.
The engine turns freely by hand. includes the weber carbs and air filter housing.
I will need to search through the boxes and tubs to see what all components are there. Of the unique 6 items, I know it has the heat exchangers, the oil tank & console, steering wheel, etc. but I don't think it has the rear brake calipers. It also does not have a windshield. It does have a very good condition original dash pad, drivers seat, and back pad. The passenger seat pad needs to be recovered.
I will be traveling this week, so I may be a little slow on responses. It will be next weekend before I can do a little more review of the parts.
[/b]SOLD- deposit received[b]. Thanks for looking!
