QUOTE(sixnotfour @ Jun 13 2019, 12:22 PM)
well someones been doing something to em..bummer, first holes look like tapered seat inserts, the one hole looks flat and not concentric to the insert..is that correct ??
fyi, wobble bolts only work for hub centric wheels..
- deciphering just what is what this exercise has been all about
I think what we see in the pic is one hole with a tapered insert, as exists in all holes. Then the pic with the bolt, has the conical washer removed [as some do, and other bolts are fixed conical shape under bolt head] from the bolt and sitting in one of the tapered inserts.
I think I will know the next step when the original style bolt arrives. but i'm nervous to remove inserts because I don't know how much the original diameter of the bolt holes have been monkeyed with.
thanks for the heads up on the wobblies - seeing how this is my first endeavor with both those, and lug centric wheels. compound issue for me figuring this out.
