Full Version: 914/6 ignition switch woes
rudedude
For a few years now the switch in my /6 has been declining in its ability to get past the run position to the start position. It can take upwards of 10 tries to engage starter. I finally ordered a new electrical portion believing that to be the issue. Now that i have the electrical part removed I see that the issue is in the mechanical part. Has anyone had one apart to see if they are repairable? Its now gone to a much more difficult fix removing shear pins and the switch than just the easy fix. Any help is much appreciated.
Thanks,
Jule
914Sixer
Maybe Dan can fix it for you. Sounds like it is just worn out. Replacements are in the $800 range.
bdstone914
@914Sixer
[/quote]
@TWEET
Dan, can you work on a 911 ignition switch?
@rudedude
Jule,
You can try Pelican 911 parts forum for a used one.
Bruce
rudedude
I spoke with porsche dealer as this is supposedly a special order, ? keyed to your vin. Is it possible to change the tumbler assembly on a used one? Or am I stuck going with porsche? It is the same ignition interlock that is used in 911 up thru 98 I believe.
Thanks,
Jule
mb911
QUOTE(rudedude @ Jun 12 2019, 08:01 AM) *
Thanks,
Jule
Tweet can do it. He did mine took a while but he was rekeying everything and he was very busy. Make sure you call and talk to him.
sixnotfour
https://www.ebay.com/str/Type-4-and-More?_pgn=2
rudedude
Thanks, I'll get ahold of him
Invision Power Board © 2001-2019 Invision Power Services, Inc.
