1971 914-4
New to me
Starting to sort out some things.
First up- turn signals.
The fuse box is missing it's cover, but the second fuse from the far right is missing...and adding one in immediately shorts.
So I pulled the flasher (as recommended on Rennlist before I found you guys!) And tested continutiy between #49 and left and right...nothing. The flasher isnte working.
Then I noticed a newer/modern looking relay hanging out behind the fuse panel...it's operating the turn signals. My suppostionn is that they have bypassed emergency flasher?
I got the turn signals working with cleaning the bulb sockets and using a little dilectic grease.
Id love to get the emergency flashers operating...has anyone else elese had anything like this?
Thanks in advance.
