Instead of going through Maryville to get to The Dragon, plan your route to go into Pigeon Forge, TN. From there, take Wears Valley Road. About halfway into Wears Valley, you can pick up the start of the Foothills Parkway which will give you ~25 miles of scenic drive along the ridge to the TN side of The Dragon.
After you've had your fill of The Dragon, head for the Cherohala Skyway (another scenic drive) which will take you west to Tellico and then I-75 for your blast back north.
OR... you could take the Blue Ridge Parkway all the way to Cherokee, NC and then west to catch The Dragon from the North Carolina side.
And when you get home, be sure to check for photos from
129photos.com. The owner is a good friend of mine and he will most likely post at least one 914 as a "Photo of the Week" on the following Monday.
