Full Version: take out odometer question
brcacti
Do I need to take the steering wheel off to take the odometer out, not a real lot of room to pull the odometer off if I don't
porschetub
QUOTE(brcacti @ Sep 17 2019, 08:01 AM) *
No ,but I always cover the steering column with tape to prevent marking the paint.
brcacti
Thanks for the information
porschetub
Also forgot to mention your speedo may be stuck in the surround after being in there for years...mine was,the rubber ring gets sticky,if you can't move it take your fuel/combo gauge out first and then reach your speedo through that opening,helps to undo/refit the drive cable also,good luck.
mlindner
porschetub, I'll second on the combo gauge out and push the speedo out.
Invision Power Board © 2001-2024 Invision Power Services, Inc.
