surfdogskier
Oct 7 2019, 06:22 PM
Oh my gosh!!!! She is back to doing this same thing all over again. I finally got her running . She ran fine one evening, parked her. Next day she would not start. No power to the injectors. I got spark. I got gas in the lines. Fuel pump works like it should. I took the distributor out and cleaned the trigger points to see if that would help. All wires are connected. MPS connected. All vacuum lines connected. I bought a noid light set up and they are definitely not getting power.
What else could it be? Something on the relay board? Bad relay?
This car is driving me insane. I am about to go duel carbs and drop this piece of **** fuel injection if I can't get this thing running.
Mikey914
Oct 7 2019, 06:27 PM
It injection is the best way to go if you can keep it running. What motor?
All 4 I suspect trigger points.
Factory spacing is 23mm
JeffBowlsby
Oct 7 2019, 06:51 PM
I know you said “all wires” but does that include the three pair of ground wires in the FI harness?
JeffBowlsby
Oct 7 2019, 06:52 PM
Dup post, sorry
surfdogskier
QUOTE(Mikey914 @ Oct 7 2019, 08:27 PM)
Sorry about that. 1.7. It is all four. I pulled the trigger points and cleaned them. The 3 wires look to be in good condition and the plug.
surfdogskier
Oct 7 2019, 06:54 PM
QUOTE(JeffBowlsby @ Oct 7 2019, 08:52 PM)
Yes. I actually stripped these down and put on new leads and clips.
JeffBowlsby
Oct 7 2019, 07:10 PM
Remove the ECU from the FI harness. Leave the harness plugged into the relay board and turn the key to “on”. Do not crank the engine. Do you get 12V between ground and the ECU connector on the harness, at pins 16 and 24? The cavities are numberd on the ECU plug, look carefully.
If no, any change if you wiggle the harness?
Mikey914
Oct 7 2019, 07:25 PM
Check power on 16 and 24 if not possible relay board issue?
I know Brad Mayer 914LTD has them rebuilt at about $200 which is less than I paid when mine went out.
surfdogskier
Oct 7 2019, 07:47 PM
I will do that tomorrow and post back.....Thanks for the help.
914_teener
Oct 8 2019, 02:50 PM
QUOTE(surfdogskier @ Oct 7 2019, 06:47 PM)
Ring out the wires on the harness as Jeff suggests.
Once you get the harness eliminated I'd seriously consider an electronic distributor like the 123 and never worry about it again. You can always upgrade your motor if you decide to go bigger later and just change the dip switch setting.
surfdogskier
In order to check the 16 and 24 pin, do I have to take apart the ECU and get inside it? The wire going into it. Can this be checked at the regulator plate?
JeffBowlsby
Oct 8 2019, 03:51 PM
Yes to the first question. No to the second.
Slide the grey plastic cover off the ECU, and pull off the plug. You may be surprised at how easy it is once you do it the first time.
jim_hoyland
Oct 8 2019, 04:18 PM
QUOTE(Cairo94507 @ Oct 7 2019, 02:02 PM)
Congratulations Lawrence. I loved your 914. Great looking car with just the right attitude. I am sure you will love the 911 and I wish you nothing but the best with it. The 3.0 is a terrific motor and with the limited slip 915 you should have lots of fun.
I have flip-flopped back and forth between 911's and 914-6's for the last 40 years. In the end the 914-6 was the winner for me. I may buy an '89 Carrera coupe one of these days if I am around long enough. That is the only 911 I really want to share the garage with the 914-6.
Cheers and I hope to see you soon.
Michael
What's going on at 16 and 24 ? Power coming inputs ? Or ?
surfdogskier
Oct 8 2019, 05:41 PM
QUOTE(JeffBowlsby @ Oct 8 2019, 05:51 PM)
Thanks for clarifying. I looked and thought I had to pry all those clips up and then bend them back.....I will go from there and post back.
surfdogskier
Oct 8 2019, 06:21 PM
I do have 12v at 24 and 16.
IronHillRestorations
Oct 8 2019, 06:25 PM
Just because you cleaned the trigger points, does not make them work.
Oct 8 2019, 06:32 PM
Where are you in east TN? I'm moving to Charleston, near Cleveland
JeffBowlsby
Oct 8 2019, 07:12 PM
Then you have power to the ECU. Somewhere between the harness plug and the 2 wire injector connectors is the discontinuity. The trigger points initiate the voltage pulse to the injectors. The ECU processes the several engine sensors to determine the pulse width. No power to the injectors at idle could be worn out trigger points, a bad ECU, disconnected injector grounds, bad harness wiring. Maybe more. I would check the trigger points as has been mentioned, use an ohmmeter. Pull the dizzy, or check it in the car while cranking. You are looking for alternating continuity between the center pole and each of the two outer poles as the diz is rotated. No continuity, no pulse, no voltage, noid light no worky.
surfdogskier
Oct 8 2019, 07:26 PM
QUOTE(IronHillRestorations @ Oct 8 2019, 08:32 PM)
I live in Sevierville. Charleston is about 2 hrs away.
surfdogskier
Oct 8 2019, 07:29 PM
QUOTE(JeffBowlsby @ Oct 8 2019, 09:12 PM)
Not a big deal to take her out. I will pull it tomorrow and try this....Thanks again for all the help Jeff. Much appreciated.
surfdogskier
Oct 8 2019, 07:36 PM
I do want to mention. If she sets for a little while and I go to crank her, she will try to turn over. It is like she is getting a spitter of gas. It is much like if you spray starting fluid and it hits the plugs except it doesn't last but a second or so.
I am going to check my trigger points again like I mentioned. One thing also when I was going through this before is the MPS. If it was touching metal it seems like, the car would not start. I would move it and she would start. I also noticed the plug can go in both ways but only one way allowed it to start. Now I have her mounted where she suppose to go but I just wonder if that could be my issue. Anyway to check that? Do these things go bad?
914_teener
Oct 9 2019, 09:58 AM
QUOTE(surfdogskier @ Oct 8 2019, 06:36 PM)
Wiring. But check them anyways as Jeff has said.
Most problems with the stock FI are wiring.
I'd take the whole harness out....ring out all the ends and clean all the grounds while you have the dizzy out.
Visually inspect it. If there are cracked wires.....I'd hit up Jeff for a new one.
Bartlett 914
Oct 9 2019, 02:59 PM
How do you know you are not getting power the the injectors? This is not a static signal. Pull one and point it into a jar and crank it. Make sure you are getting something or not. Are you sure you have fuel pressure?
dr914@autoatlanta.com
Oct 9 2019, 03:03 PM
probably two of the injectors spitting a bit of gas when the key is turned on. You can turn the key off on off on off on off on and then hit it and if the car starts and dies, you know that the two of the trigger points are sending a signal.
By the way, will the car run continually if starting fluid or gas is sprayed into the throttle body?
surfdogskier
Oct 9 2019, 06:23 PM
I is like it has a drop of gas to tease it. I tried that with the starting fluid and it didn't go so well. Ended up catching my engine on fire for a bit. Fortunately nothing was really harmed other than some singhed wires which I replaced.
surfdogskier
Oct 9 2019, 06:24 PM
QUOTE(Bartlett 914 @ Oct 9 2019, 04:59 PM)
I put a noid light on them and no power. All my plugs are firing.
surfdogskier
Oct 9 2019, 07:09 PM
Trigger points have continuity. Tested with a ohm meter. That eliminates that. And they are very clean when I pulled them them the first time.
surfdogskier
Oct 11 2019, 09:38 AM
I decided I am finished with fuel injection. I don't trust it and not dropping anymore into it. Converting to carbs.
ClayPerrine
Oct 11 2019, 09:41 AM
QUOTE(surfdogskier @ Oct 11 2019, 10:38 AM)
You will hate the carbs even more. Poor mileage, gas smell, etc. And you have a lot of fabrication to get the throttle hooked up. And lots of patience to get them synced and running correctly.
I would suggest finding a local 914 guru (there are a lot of them on here) that is willing to help you sort the injection before you bail and switch to carbs.
surfdogskier
Oct 11 2019, 07:30 PM
QUOTE(ClayPerrine @ Oct 11 2019, 11:41 AM)
I can't imagine hating anything worse than this. I have dropped a lot of money in this thing to get it running. My friend has one with carbs and he loves it. This has been a project over the past year. Mileage and smell don't bother me. I'm a diesel guy so I am use to that. It's to the point you jump in the car and wonder will it start and if it does for how long. To many variables to worry with. I not in it for keeping things original and stuff. She is being created as a fun car to just scat around in in the summer primarily.
Oct 12 2019, 07:27 AM
Just don't over size the carbs; bigger isn't better, correct is better. Buy from a vendor that will size the carbs to your engine. Get a distributor from a 1.8 and connect the vacuum advance, don't use a 009.
I'd be the last person to dog on you for ditching the injection, I did the same years ago when I had to rely on my 914 as a daily driver. Yes, there are downsides, but not being able to trust and drive your 914 is a bigger downside.
Bartlett 914
Oct 12 2019, 03:25 PM
QUOTE(surfdogskier @ Oct 9 2019, 07:24 PM)
I have never used a noid light so I don't know how that would work on an injector circuit. I am still suspicious about this being an injector firing issue. Did you try as I suggested? Remove a pair of injectors so they can be inserted in jars. Try starting several times to see if you are getting fuel. Are you sure you have fuel pressure? I am a firm believer in the KISS principle. Keep it simple and make sure all the basics are covered before jumping into more complicated causes
surfdogskier
Oct 12 2019, 06:04 PM
QUOTE(Bartlett 914 @ Oct 12 2019, 05:25 PM)
I did not pull the injectors since I had a noid light which showed no power. All 4 plugs have fire so they are obviously not get any gas being supplied by the injectors. Again, to many issues with fuel injection. I am going to make it simple. I am converting to carbs which I have already bought along with new fuel pump and distributor. I am so looking forward to ripping this stuff out and moving on.
Anyone interested in a fuel injection set up, I will be selling it all.
ClayPerrine
Oct 12 2019, 06:54 PM
QUOTE(surfdogskier @ Oct 12 2019, 07:04 PM)
How much?
rhodyguy
Oct 12 2019, 07:16 PM
By the time you've done the swap you'll be in another $800+ just in NEW parts. You would be better off having an outfit like Ironhill examine your car. Perry knows what he's doing. Are you two in distant corners of Tenn?
surfdogskier
Oct 12 2019, 09:40 PM
QUOTE(rhodyguy @ Oct 12 2019, 09:16 PM)
He's in West TN and I'm in East TN. I already got my setup ordered for me to put in next week.
surfdogskier
Oct 12 2019, 09:41 PM
QUOTE(ClayPerrine @ Oct 12 2019, 08:54 PM)
How much?
That I do not know. I want to get my carbs installed and running first then deal with that. I have no idea what I can get out of it. All new injectors and new fuel pump.
JeffBowlsby
Oct 13 2019, 12:10 AM
Surfdog, please don't take this personally, just trying to turn this into a learning experience for all, going forward. These are old cars. If these parts are work out, then they may need replacement - standard maintenance for any car.
The easy thing and for some, the hardest thing about D-Jet is that there are only a limited number of components, and each of them can be tested individually for function with either an ohmmeter, fuel pressure gauge, a few simple tools, or a service can test these for you. If each of these tests good, then the system is plug N play. If not...maybe its another problem and not the FI?
ECU - rarely go bad...but maybe. Not expensive to replace.
FI harness - simple continuity test, new are available.
IGN harness and tri-spade ground, - simple continuity test, and new are available.
MPS - easy to test with the right equipment, rebuilt available, not expensive.
Trigger points - easy to test, lasts a long time and can be adjusted if worn.
TPS, with gaskets - inexpensive new boards are available.
270ohm resistor (1973 2.0L only)
4 fuel injectors - Maintenance cleaning is not expensive, aftermarket injectors available
1 cold start valve injector and thermo switch (optional)
TS1 (air temp) (optional)
TS2 (head temp), available
Fuel pump, spendy for the OEM, functional alternative pump not expensive.
Fuel pressure regulator - do these ever go bad?
The air supply related parts - rarely a problem unless the plenum or gaskets are leaky, and those are repairable/replaceable.
surfdogskier
Oct 13 2019, 08:32 AM
QUOTE(JeffBowlsby @ Oct 13 2019, 02:10 AM)
Hey Jeff. Thanks for all the help you have given. Definitely not taken personally. I wish I could leave it but to many unknowns still. I just didn't want to keep dropping $$$ into something which I lost trust in. Just way to many components to keep up with when I can just convert it over to something much easier and in my opinion, more reliable. I just want a car that will start when I need it and take me from point A to point B and back. Don't need performance or gas mileage where my top speed will rarely exceed 55mph.
JeffBowlsby
Oct 13 2019, 10:13 AM
No worries Surfdog, you are entitled to make the decision that is right for you.
I hope its not some other non-FI related issue that is the problem.
