Full Version: Center Console Clock Rubber Seal
63acornwall
I now have a working VDO clock for the center console but am missing the rubber seal to mount it with .
Hole in console is 80mm diameter , clock is 60 mm diameter .
Where can I get the rubber seal from ? breakers yard ?? not sure how to describe it for an ebay search !
ConeDodger
Hmmm... I wonder if 914rubber.com would have that?
Yup!
@mikey914
yellowporky
914 rubber did not carry in the past but recently Auto Atlanta said that they carry them. I need all 3 center console rings too
dr914@autoatlanta.com
Factory vdo console gauges are 60 and use a rubber sleeve to fit which we now make. Aftermarket vdo are 50 and use a spacer ring to fit into the factory console hole
QUOTE(63acornwall @ Nov 7 2019, 07:50 AM) *
63acornwall
QUOTE(dr914@autoatlanta.com @ Nov 7 2019, 03:35 PM) *
thanks dr914 , how do I find it on your site ? ( did a search earlier today before I posted but failed to find it )
FlacaProductions
I actually need all 3 for the stock/oem console gauges.
Are all 3 60mm?? Who has 'em - i've looked....
Mikey914
We make the 100, the 155 for the main gauges and the 80 for the 911 clock,
We can make the 60's also as we do sell the center consul
https://900designs-container.zoeysite.com/search/?q=guage
no reason to Mark, we have over 100 in stock
QUOTE(Mikey914 @ Nov 7 2019, 11:04 AM) *
FlacaProductions
show me a link please, George - I ended up asking here because I know @Mikey914 doesn't make them but I've searched 3 different ways on your site and can't come up with them. It shouldn't be that hard....
mmichalik
QUOTE(FlacaProductions @ Nov 7 2019, 10:47 AM) *
if you search for " RUBBER MOUNTING RING 914" on the AA site you should see them.
FlacaProductions
Closer. So they’re 80mm for the stock console gauges?
That site is still clear as mud. Maybe I’m slow.
Mikey914
QUOTE(FlacaProductions @ Nov 7 2019, 11:52 AM) *
80 is the 911 dash clock
FlacaProductions
@mmichalik - I appreciate the help but if I search "RUBBER MOUNTING RING 914" I get a page that shows me 18 items including 115, 100, 80 and 75mm.
I see no 60mm and the only ones on that page that are indicated to be for a 914 are the 115 and 100's. WTF.gif
63acornwall
QUOTE(FlacaProductions @ Nov 7 2019, 09:33 PM) *
Same thing I found ....
FlacaProductions
Good, (I guess?!)
I'm not crazy, then.
Anyway - I've had two very nice offers offline regarding acquiring these....
mmichalik
QUOTE(FlacaProductions @ Nov 7 2019, 02:00 PM) *
Good, (I guess?!)
Ah, thought I had saw them. Just did a quick check trying to help out.
Hopefully the offline offer comes through for you
FlacaProductions
Thanks @mmichalik - no worries - I appreciate the help.
Mikey914
Hey George
Waiting on the response on the
