@DRPHIL914' date='Nov 8 2019, 02:08 PM' post='2760458']
not I was referring to the bolts that hold the front shock tower in place 4 of them , and the nut that holds the top concave washer on the top of the front strut , and that large concave washer too.
-let me know on the steering u- joint. if yhou are out I can wait until another run of them just put me on the top of the list, it may be a while before I do the steering rebuild and get into that, but right now I would like to do the rest of the hardware on the struts .
Phil
[quote name='bdstone914' date='Nov 8 2019, 11:12 AM' post='2760397']
@DRPHIL914 date='Nov 8 2019, 08:12 AM' post='2760364']
bruce I will take a set of U-joints and a set of the rear shock bolts!
Phil
$88.00?
@bdstone914also - I got from you at the Okteenerfest the 2 front shock things but you didn't have the cup washer or nut or bolts, so if you ever do those id like to complete the look, I just put the other half moon washers in place and now those screws the nut and center cupwasher don't look so good in comparison!
[/quote]
Let me get a count on thr u joints. I think you will be getting the last pair.
Not clear on what added hardware you need.
I think you are referring to the bumper shock hole cover plates. I just found them there. Not sure what size hardware is needed.
Bruce
[/quote]
[/quote]
Ok, i know what you need now. I do have a pair of u joints for you. Pretty sure i have the strut cup washers too.
Bruce
