Full Version: Visor won't say up
R Dub
My driver's side visor will not stay up. It always falls in the down position. Passenger one is fine. Any idea how to fix this?
DickSteinkamp
QUOTE(R Dub @ Nov 7 2019, 05:41 PM) *
Tighten the small screws a little at the center pivot and the outside mount.
FlacaProductions
If those are tight, make sure the pins are firmly seated in the mounts. Those pins shouldn't spin. They should be stationary and the visor pivots on them. If they spin, take the whole visor off along with the mounts, separate it all and insert the pins in the mounts. Give them a light tap with a hammer and/or apply a little glue and then reinstall in the car as a unit.
R Dub
I'll check it out. Thanks for the input
