QUOTE(rjames @ Jan 2 2020, 10:57 PM)
QUOTE(Rand @ Jan 2 2020, 05:06 PM)
I appreciate Brad as much as we all do.
Spacers that were never factory are band aids. Can we stop the band aids and get to the real problem? We need a baseline. Obviously there's something else wrong. Please don't try patching it other ways. Fix the source of the problem before you chase mysteries the rest of your car life.
Fully agree with Rand.
Provide some more info: Has the car always done this or did the issue just start?
Things that immediately come to mind:
Verify the correct model year DJet parts are installed
Injector wiring harness is good
Vacuum hoses hooked up incorrectly
Vacuum can on distributor leaking
intake runner hoses
throttle body gasket
Leaking plenum (only way to do this is to remove it from the car)
bad injector seals
Idle mixture knob on the ECU is not set correctly
Bad MPS
...to name a few.
If the idle is surging I would start by adjusting the ecu knob to see if that changes anything, then test the MPS and dist vacuum canister to see if they hold vacuum. If it's not surging the MPS could still need to be adjusted.
My fluctuating idle issue (from 900-500 rpms) turned out to be a combo of a throttle body with a worn shaft, a bad vacuum canister on the distributor and a bad MPS. (And I'm probably forgetting something else.)
This issue started recently. I've been chasing a typical erratic idle for some time but this rough idle started after rebuilding the distributor and replacing the MPS. I've successfully tested almost every component and sorted all other issues with the exception of this one.
MPS is newly rebuilt, trigger points, AAR, decel valve, fuel pressure, hoses, injector boots, intake sleeves, verified '74 2.0 d-jet parts, timing, valves, etc.
Today I tested both the new (012) CHT and the 20+ year old one that was in the car. I tested both CHT's in and out of the car with interesting results. In the car the NEW CHT (012) worsened the problem. The engine dropped off the high idle in less than a minute and then idled a little worse than it did with the old CHT.
OLD CHT: 2600 ohms @ 68F, 195 ohms @ 176F, 146 ohms @ 190F
NEW CHT: 2400 ohms @ 68F, 181 ohms @ 176F, 120 ohms @ 190F
The new CHT definitely made the car run even leaner and drops off the high idle faster than the old one.
My plan of action is to verify the injection wiring harness, test the injectors and try Brad's spacer on the old CHT next. I'm wondering what else makes a 914 lean during idle?
Really want to get this little screamer back on the road asap.
