Full Version: Weltmeister 19mm front sway bar bushings
naro914
A friend of mine is looking for the bushings for where the bar goes through the body for a 19mm Weltmeister sway bar. Any idea where to get these?
dr914@autoatlanta.com
rose passion internet parts company in france, they bought weltmeister
QUOTE(naro914 @ Jan 17 2020, 08:48 AM) *
Mikey914
Is this the one you want?
https://900designs-container.zoeysite.com/f...-body-bushing-1
We also have the drop link ones too
naro914
QUOTE(Mikey914 @ Jan 17 2020, 11:21 AM) *
Kinda...but I think that's OEM.
Welmeister doesn't have the 'lip' on it.
See this thread - part S
http://www.914world.com/bbs2/index.php?showtopic=327883
914werke
QUOTE(dr914@autoatlanta.com @ Jan 17 2020, 07:53 AM) *
Ya but they arent producing any of those products. AFAIK just selling off existing transferred inventory.
Luke M
I know that I have a few new sets. I'll post some pics after I locate them.
Maybe Mark can reproduce them??
jim_hoyland
QUOTE(Luke M @ Jan 17 2020, 03:35 PM) *
Great idea !
Literati914
I have a 19mm bar too, could probably use new bushings as well.
jim_hoyland
QUOTE(Literati914 @ Jan 17 2020, 08:31 PM) *
Back in the day; Weltmeister Sold a lot of these sway bars to 914 owners- I got one too...
sixnotfour
beerchug.gif they are really simple to make ..simple lathe job
https://www.rosepassion.com/en/parts-porsch...mm-1309-0-87650
Luke M
I found my welt sway bar and bushings. The one I have is a 22 mm but the bushings look the same as a 19 mm. I believe my brother has the 19 mm one for his 914.
Anyways, I have two different type of bushings. One set is for the welt bushing cups and another set for the factory cups. These should be pretty easy for 914rubber to knock out. Both bushing sets are made from a hard plastic. See pics.
mskala
I just did some bushing work on my old 19mm Weltmeister front bar.
The bushings are not quite the same as the ones shown for 22mm.
I made new out of delrin, which is probably not the best material for
this but the huge bearing surface should make it okay for most uses.
The dimensions you need are 1.505" long, 1.128" OD, 0.752" ID.
No lip on either end, the piece bolted to the fender well has a stop on
the inside. As others have said, there is some room for the bar to
move sideways, so be prepared after pushing the arm as far as it will
go, to have a small spacer to fit in-between the bushing and arm.
Shivers
QUOTE(mskala @ Oct 22 2023, 02:48 PM) *
“As a bushing material, delrin boasts many important properties including high tensile strength, high impact strength, high elongation, high chemical resistance, low moisture absorption, and more. In addition to low deflection, delrin's best feature when compared with polyurethane is self-lubrication.”
https://ridetech.com/why-you-need-delrin-th...f%2Dlubrication.
Invision Power Board © 2001-2024 Invision Power Services, Inc.
