Full Version: New GB - Electrical - Ignition and fuel injection harnesses
Mikey914
We have been doing these for a while now. We want to bring the cost down, and doing these in quantity will allow for us to to reduce the cost and pass that on. We are looking for 10 of each to get the pricing good for you.
1st
The ignition harnesses -
We have the replicated all of the parts including the L shaped tube at the transmission reverse light.
We have the
70-71
72
73-76
We have these for sale on the site but want to gear up to make in bulk and are offering a price for the GB if we can get 10 takers.
These are correct color coded wires and plugs
Just +1 Ignition harness and the year
we need 10 and can provide these for $210 reg 250
25 and we can make for $199
Mikey914
Now for the Fuel Injection harnesses
These will save you hours of tracking down shorts that are intermittent.
We have the
72+ 1.7 L
and the 73 20.L harnesses
we are just finishing up the early 70-71 harness this week
And can do a 1.8 harness if there is an interest
we have reproduced all the parts needed to make these even the D grommet at the ECU.
As well as the circuit board mount clip. Notice the way we wrap the wires so they will not pull. The only part we didn't reproduce is the "handle" that screws into the bracket on the board, as you shouldn't need to replace them. Ours will accept the old handle.
Best of all we label our ends. Is this the #3 or #4? pretty easy to tell. As well as the other ends. We have taken the liberty of creating a common ground for the 3 leads that require it. easy enough to un-clip and go direct if you wish, but we tried to make it as easy as possible.
These normally go for $494 each, but if we can get 30 takers we can sell these at $399 each. I'm hoping more as we may be able to reduce further if we get the economy of scale
Just need a +1 for the F/I harness with engine and if it's 1.7, early or late.
I think you will like these.
https://900designs-container.zoeysite.com/1...-wiring-harness
ctc911ctc
Put me down for one of each,
C
jesse7flying
+1 Ignition harness for a '71.
9one4tay
+1 ignition harness for a 74'
914four
73-76
The quality appears to be good from the pictures. If you get enough for the GB I'm in for an ignition harness for a '74.
Kelvin
walterolin
One of each for a 1970 1.7.
Thanks
lvnzdrm
I purchased and installed the FI harness into my 72' it fit like a glove and all connections worked perfectly. Connectivity is awesome and car runs great.
ctc911ctc
QUOTE(lvnzdrm @ Feb 9 2020, 02:44 PM) *
pvollma
+1 on ignition harness for '76
Maury4
I need 1 for '74 1.8
Mikey914
QUOTE(Maury4 @ Feb 10 2020, 07:22 PM) *
Ignition or F/I harness?
Maury4
I need Ign harness for '74 1.8 for 1.
thanks,
Rick
Mikey914
Ignition I have. We are still working on the fuel injection harness now.
Rikyrat
+ 1 ignition Harness 74 1.8
Rick Gould
Chris914n6
Ignition harness is different between Djet and Ljet.
potomacmidget
+ 1 for ignition for 71
+ 1 for 71 FI harness
Thanks,
Reg
Rob-O
‘74 1.8L FI harness for me.
914Sixer
Best investment you will make for a good running engine. Engine electrical gremlins are a pain.
seanpaulmc
Is there a close date on this GB?
Mikey914
Really need 10 commitments of each to make at this price. I do have most in stock, just the cost to make individually is higher. I'm looking to save the difference in economy of scale.
914sgofast2
I would like one of the 73 fuel injection harnesses, for a 2 liter engine.
