Pair of speedo drive bushings with pinion shafts, pinion has 23 teeth, 26mm diameter I'm assuming that these are for 4cyl 914, 6cyl has different P/N for the pinion $20 each plus shipping Click to view attachmentClick to view attachment
Geo9146
May 2 2020, 12:17 PM
Bump $10 each plus shipping
stevegm
May 2 2020, 01:39 PM
I’ll take them if we can confirm they are for 914. I’m sure someone will chime in.
Geo9146
May 2 2020, 02:19 PM
PET lists the same PN 901 318 243 12 for both 914 and early 911 However, the pinion shafts are different numbers The ones I have are 23 teeth, so check see what the 914 has
QUOTE(stevegm @ May 2 2020, 12:39 PM)
infraredcalvin
May 2 2020, 11:05 PM
I’ll take them if Steve passes. LMK.
Thanks!
914werke
May 5 2020, 11:52 AM
Interesting. Never noticed that the tooth count on the speedo shafts differ between /4 & /6. I wouldn't have guessed there was significant enough difference to warrant.
Geo9146
May 11 2020, 01:41 PM
No reply yet from SteveGM You still interested, infraredcalvin?
Geo9146
May 26 2020, 10:40 AM
Bump $8 each plus shipping
